Installation & Licensing
AutoCAD Electrical 2012 Symbol Libraries Locations
3 REPLIES 3
randywestrate
12781 Views, 3 Replies
I believe these two
issues are related.
  1. On Installation, The
    location for the "Default Drawing Standards" is "Z:\My
    Documents\Acade 2012\" but the system will not let this remain. I first
    time I installed the software I changed it to "C:\My Documents\Acade 2012\"
    but I had the issue as listed in #2. I then did an Un-install and made the file
    path for the "Standards"
    "C:\users\randyw\appdata\roaming\autodesk\autocad electrical
    2012\r18.2\enu\support\user\" because this is the first path listed on the
    "AutoCAD Message". Still did not work. The default path for the
    Symbol Library is "C:\users\public\documents\autodesk\acade 2012\:
  2. When I tried to add a
    wire tag to an existing drawings that I first developed in AutoCAD Electrical
    2011 I received an AutoCAD Message box station that the "File not found:
    WD_WNV.dwg", and it list several folder paths that it looked through.
Do I need to install
Electrical 2011 first . I have a new machine so it did not have a previous
version of AutoCAD on it?
3 REPLIES 3
The two drawing files that are used for wire numbers are WD_WNH.DWG for Horizontal and WD_WNV.DWG for Vertical. Both files are located in the default library you are using.It looks ACE is not finding it in your case.
This can occur when changes have been made to the environment like an upgrade or moving folders to custom locations.
The outdated paths are contained in the project file, so you must update the project paths by reading the current environment file.
Right click the current project in the Project Manager, select Properties.
Select Schematic Libraries and select the default button as shown in the image.  Repeat for the other 3 sections.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
Tags (3)
Thank you very much,
That seamed to take care of the problem.
in reply to: randywestrate
I am using acade 2009 and am having a problem with my libraries. I have found how to change the project libraries on a project to project basis to a remote location. What I am trying to do is change the "default" settings for the schematic library. I assume this is just an editable text file but cannot find it.
Can anyone help me?
Tags (1)
Administrator Productivity
