I believe these two
issues are related.
Do I need to install
Electrical 2011 first . I have a new machine so it did not have a previous
version of AutoCAD on it?
Solved by randywestrate. Go to Solution.
The two drawing files that are used for wire numbers are WD_WNH.DWG for Horizontal and WD_WNV.DWG for Vertical. Both files are located in the default library you are using.It looks ACE is not finding it in your case.
This can occur when changes have been made to the environment like an upgrade or moving folders to custom locations.
The outdated paths are contained in the project file, so you must update the project paths by reading the current environment file.
Right click the current project in the Project Manager, select Properties.
Select Schematic Libraries and select the default button as shown in the image. Repeat for the other 3 sections.
I am using acade 2009 and am having a problem with my libraries. I have found how to change the project libraries on a project to project basis to a remote location. What I am trying to do is change the "default" settings for the schematic library. I assume this is just an editable text file but cannot find it.
Can anyone help me?
