• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Product Support
    AutoCAD Civil 3D, Microsoft C++ libraries. Error 1935 and Windows 7
    4857 Views, 2 Replies
    12-06-2010 11:58 AM
    Recently, I had resolved the following issue with an installation of AutoCAD Civil 3D 2011 on Windows 7 (32 bit).  It would not install the Microsoft C++ 2005 and 2008 libraries.   We even tried to install the VCRedist manually by going into the following folder and there was a 1935 error.
    • x86-or-x64\support\VCRedist\2005
    • x86-or-x64\support\VCRedist\2008
    The solution was to set the Windows size Registry to unlimited for this component to install.
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
    Key: RegistrySizeLimit
    Type: REG_DWORD
    Value (Hexidecimal): 0xffffff
    or
    Value (Decimal):  4294967295
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
    Please use plain text.
    Product Support
    Re: AutoCAD Civil 3D, Microsoft C++ libraries. Error 1935 and Windows 7
    12-06-2010 12:01 PM in reply to: david.lau
    Product Support
    12-06-2010 01:14 PM in reply to: david.lau
    The final tip is to download and install the Civil 2011 Update 1 afterwards.  Do not include the update during initial installation in via Configuration Wizard.
    http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240698
    David Lau
