Installation & Licensing
Product Support
Message 1 of 4 (5,681 Views)
AutoCAD Civil 3D, Microsoft C++ libraries. Error 1935 and Windows 7
5681 Views, 3 Replies
12-06-2010 11:58 AM
Recently, I had resolved the following issue with an installation of AutoCAD Civil 3D 2011 on Windows 7 (32 bit).  It would not install the Microsoft C++ 2005 and 2008 libraries.   We even tried to install the VCRedist manually by going into the following folder and there was a 1935 error.
  • x86-or-x64\support\VCRedist\2005
  • x86-or-x64\support\VCRedist\2008
The solution was to set the Windows size Registry to unlimited for this component to install.
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
Key: RegistrySizeLimit
Type: REG_DWORD
Value (Hexidecimal): 0xffffff
or
Value (Decimal):  4294967295
David Lau
Product Support
Message 2 of 4 (5,675 Views)
Re: AutoCAD Civil 3D, Microsoft C++ libraries. Error 1935 and Windows 7
12-06-2010 12:01 PM in reply to: david.lau
Product Support
Message 3 of 4 (5,664 Views)
12-06-2010 01:14 PM in reply to: david.lau
The final tip is to download and install the Civil 2011 Update 1 afterwards.  Do not include the update during initial installation in via Configuration Wizard.
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240698
David Lau
New Member
Message 4 of 4 (786 Views)
06-04-2013 05:27 AM in reply to: david.lau
Solution works... thanks
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
