I am having an issue with AutoCAD error with a student user. I as an administrator on the network can login and use AutoCAD 6 LT fine. A teacher can login and can use AutoCAD also. A student user when trying to run AutoCAD 6 LT gets an error prior to any splash screens. The error has no information except that AutoCAD had an error. The only thing I can think of is that the students do not have access to the C: drive. I did notice all temp folders are set for the C: drive. Could that be the issue? If so, is there a way to workaround that reqmt?
This is a really old version of AutoCAD and is not supported. We only support 2013-2010 versions. You may need to review this document:
http://usa.autodesk.com/getdoc/id=TS1055299
The student account needs to be Admin upon first launch.
