Installation & Licensing
AutoCAD 2015 student network error
4 REPLIES 4
Bobpod
2621 Views, 4 Replies
Was downloading the Student Edition of AutoCAD 2015 (using the install button) and received a network error.  I finished my download using the browser and now it says I already have AutoCAD 2015 installed.  It installed the the tools but not the actual program.  I tried removing it through the control panel like the "help" suggested but it doesn't work, says the program not there/installed.
Bob
4 REPLIES 4
TravisNave
in reply to: Bobpod
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-perform-a-clean-un...
For all other installation problems carefully consider using the Microsoft Installer Clean Up Utility at your own risk. For more information on this program, please thoroughly read my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Bobpod
in reply to: TravisNave
Thanks Travis !
That worked perfect !!
(smiley face with two thumbs up)
Which one of these addresses the Network error issue?
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Autodesk Forums:
Administrator Productivity
