Installation & Licensing
AutoCAD 2015 Unable to start 0xc0000142
55 REPLIES 55
Message 1 of 56
eric.a.bogenschutz
56713 Views, 55 Replies
Brand New fresh install of AutoCAD 2015 and it won't open. Returns the following message: The Application was unable to start correctly (0xc0000142).
Tried to install it on 3 various machines, all Windows 7, all 3 have the exact same message. Thus it's not computer related, it's either something with the build or a conflict with other software that is on all 3 of my PC's. (I.E. it's a pretty common software that it's conflicting with)
Dissappointing wanting to kick the tires on a new release and it won't even open! It's usually Christmas time for us Autodesk users, I just opened a present and found a lump of coal! 🙂
Eric Bogenschutz
55 REPLIES 55
Message 21 of 56
Just an update, David.Lau posted this as a means to help narrow down the problem on each specific machine:
http://upandready.typepad.com/up_and_ready/2014/03/autocad-2015-application-error-0xc0000142-autorun...
Thanks!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Tags (1)
Message 22 of 56
sbenadiba
in reply to: TravisNave
It was my 32-bit NVIDIA dll file that was causing the problem. (and I did not have Adobe Acrobat on my computer.)
Thanks for Solution @TravisNave
Message 23 of 56
tkwelding
in reply to: Alfred.NESWADBA
I too was having the failure to start issue with acad.exe I uninstalled the acrobat 64 bit extension and that fixed the problem.. thanks
Message 24 of 56
zenkai
in reply to: tkwelding
This worked for me
used Regedit
went to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows\LoadAppInit_DLLs
Changed value from 1 to 0 and BAM it worked perfect
Tags (1)
Message 25 of 56
systemswest
in reply to: zenkai
This last regedit suggestion seems to work, trying it now. I did a fresh install on a fresh new outta the box HP and the install had no issues. Tried on my current cpu, and I get error 0cx0000142. Uninstalled and reinstalled and still the same problem. Simply did the reg edit as suggested and autoCAD started right up. Odd
Message 26 of 56
Matt116
in reply to: systemswest
Win 7pro 64bit sp1
adobe acrobat X pro
GeForce GTX 550 Ti Ver 335.23
The regedit is the only thing that worked for me to get ACADE 2015 working...
Message 27 of 56
bluesxu
in reply to: Matt116
My problem still there. I did all the tips you suggested above, remove arobat, disable AV firewall, changed registry key, and updated graphic driver...
Lenovo ideapad y510p
i7, 8 GB RAM, NVIDIA Geofore 750M
I can open 2015 trial version, but as soon as I opened it, it became No Response.
Tried all means and unable use the Civil 3D 2015 trial version... :(((
Any tips could help me out with this issue?!
Message 28 of 56
brick
The regedit hack worked for me also
WIndow 7 ultimate x64
i7-2600K 32GB
2 - Nvidia GTX660 3gb SLI
driver 9.18.13.3523
4 - 27" Monitors
Message 29 of 56
imissnumber3
in reply to: zenkai
Worked for me too. Win7 x64. I did the Acrobat uninstall. No help. Registry edit did.
used Regedit
Thanks zenkai
Message 30 of 56
I have tried uninstalling and reinstalling twice now with no success. I had Adobe 11, uninstalled that restarted and reinstalled. restarted again and tried to boot up autocad 2015, still no luck. That lump of coal I opened just seems to be getting bigger
Message 31 of 56
systemswest
in reply to: JasonMarshSFX
Try the registry edit, that's the only thing that worked for me on a working machine.
When doing a fresh install on a fresh out of the box computer I've never had a problem.
(AutoCAD is normally the first thing installed.)
William Boyanton
Mechanical Designer / BIM Specialist / IT Administrator
[cid:image003.jpg@01CE44D4.DD6A74A0]Systems West Engineers
p. 541.342.7210
systemswestengineers.com
P Please consider the environment before printing this e-mail.
Message 32 of 56
JasonMarshSFX
Hi William, already tried this route, also uninstalled adobe acrobat as
this was also a suggestion. I have noticed that when I change the regedit
to a different figure (i.e. from 1 to 0), it doesnt stay changed. IT is not
my strong point and am now completely perplexed. The system is new and
custom built for these apps. Windows 7 pro. , Nvidia k4000 graphics card,
fully updated as is windows. 16gb RAM, and a 3TB hard drive as well as a
500GB SSD. Its been a frustrating day to say the least and I just want to
start seeing what this new software and system can do.
Best Regards
Jason Marsh
Special Effects Senior Technician
Taurus
High Command Productions Ltd
Warner Bros Studios Leavesden
Warner Drive
Leavesden
Herts
WD25 7LP
Office - 0203 427 0326
Mobile - 07976619314
Message 33 of 56
Hi Alfred, from reading some of your comments, you may be able to help me. I have had the most frustrating day trying to install Product Design suite 2015 of which Aotocad Mechanical and electrical come up with that error code 'unable to start, error 0xc0000142. 3Ds max, Inventor Professional, Navisworks all loaded and opened. Only the Autocad applications failed to launch.
Operating on Windows 7 Professional 64-bit. 16GB RAM, Nvidia K4000 Graphics card, 3TB hard drive and 500GB SSD.All brand new
Ihad already loaded other software like Adobe for instance. After reading your other posts this was my first try, then, also, the registry edits to which i found 2 that were listed. I did note however that when the 1 was changed for a 0 OK'd and then window closed, I opened the registry again befor even reloading Autocad and the change had not been saved. This process was repeated and tried again many times without success. I finally loaded a registry cleaner recomended of course and ran scans. There were plenty of issues and all was fixed, a restart and another reload but still no luck. SpeedyPCPro. Reading other things tonight on Wiki Fixes shed some light on the whole enigma of dll's. After all the restarts and uninstall and installs, how do I check that each one of these operations has not left some kind of mark and therefore recurring problem with the registry.More to the point, why have autodesk not fixed the problem themselves with an update or service pack. I have wondered of the resolution is not compatible but surely it would just downgrade it accordingly.
Any help greatly appreciated before I defect to Solidworks.
Kind Regards.
Jas
Message 34 of 56
arthur.macrae
I have tried all the suggestions in the emailss under http://autode.sk/1k9JRzx" and non of them work.  Is there a problem at Autodesk in that I can't speak to a human? Are there any there?
I too was hoping for Christmas and got a lump of coal.
Message 35 of 56
Ropespierre
I have been running AutoCADLT for over a month with Adobe Acrobat Pro 10 with no problems.  Today I did a simple thing like editing color of a text objece and the system crashed.  When I went to restart I got the 0xc0000142.  I rebooted and got the same error.  I really am not excited about uninstalling and reinstalling as I purchased both as downloads and worry they will tell me that I have already downloaded what I paid for.
Ropepierre
Message 36 of 56
Here is the solution that worked for me. I didn't have Adobe 9 and I tried the Regedit fix and didnt' work.
Found this here: http://knowledge.autodesk.com/support/autocad-ecscad/learn-explore/caas/sfdcarticles/sfdcarticles/Th...
It suggested unistalling a program called "Search Protect" which I  didn't even know I had. Apparently it's supposed to keep another program from changing your prefered search page. Not an issue, so I unistalled it (from your standard software uninstall page on control panel)...clicked the icon and the program started right up.
Weird, but I'm gladd it's finally resolved (PIA!) I think the problem is that when ACAD 2015 starts it immediately tries to alter your browser setting to Internet Explorer 11 which I do not use. The Search Protect program must "see" that that ACAD is "looking" to mess with your registry lock that Search Protect installs and prohibits the start. Hey, Autodesk, we really don't need you messing with our browser settings.
Hope this helps the next guy (or gal).
Message 37 of 56
stevetamplen
Same error on my system, and none of the AutoCAD 2015 (Electrical, Std, Civil 3D) would run. 2014 and below ran OK though. Went to the UpandReady site and checked out the MS Technet download of Autoruns per the suggestion, and my problem .DLLs were from a program called Performance Optimizer:
performanceoptimizer.dll &  performanceoptimizer_x64.dll.
Uninstalled it and everything started up normally again.
I LOVE Autoruns! That program is a keeper!
Steve Tamplen
Technical Support Specialist
Message 38 of 56
I keep getting this error when trying to install Autocad 2015:  Setup.exe Entry Point Not Found
I have CS3 which has Adobe Acrobat 8. I really need Autocad for my school, but I need CS3 for my job! I don't want to delete it. I also have Avast, which I can disable.
Can anybody help?
Message 39 of 56
thanks CNY...its really works. donno when did i install that stupid search protect on my pc
Message 40 of 56
I have the same problem,
Adobe 9 is installed and I am really hesiatnt to uninstall it just becuase of this
I uninstalled Civil 3D 2015 and tried to reinstall it but now there is a message that a newer version is already installed, I assume this is the SP2
Wow...
How about bringing the programming house back to the good ol' US of A
What did Autodesk do, forget to pay their software developer subcontractor, or maybe the subcontractor forgot to pay the subcontractor --> I think autodesk has finally morphed into a solid briefcase company
Forest Peterson, granite@stanford.edu; build-sheet
Administrator Productivity
