I've tried following the instructions for the issues others have been having, like editing UAC, deleting .Net Profile and Extended, deleting TEMP files, etc. but it hasn't helped at all.
This is the screen I get after it fails.
And these are the two logs that it gave me:
2014/3/24:12:53:12 Cam CAM-PC === Setup started on CAM-PC by Cam ===
2014/3/24:12:53:12 Cam CAM-PC Path_Length: 155
2014/3/24:12:53:12 Cam CAM-PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/3/24:12:53:12 Cam CAM-PC Launch
2014/3/24:12:53:12 Cam CAM-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setu... /SN 900-44382778 /PK 001F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/3/24:12:53:12 Cam CAM-PC Current Directory C:\Users\Cam\AppData\Local\Temp\_AI81CC.tmp
2014/3/24:12:53:18 Cam CAM-PC === Setup ended ===
2014/3/24:12:53:14 Cam CAM-PC === Setup started on CAM-PC by Cam ===
2014/3/24:12:53:14 Cam CAM-PC Path_Length: 155
2014/3/24:12:53:14 Cam CAM-PC Current Directory C:\Users\Cam\AppData\Local\Temp\_AI81CC.tmp
2014/3/24:12:53:14 Cam CAM-PC Launch
2014/3/24:12:53:18 Cam CAM-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/3/24:12:53:18 Cam CAM-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Cam\AppData\Local\Temp\_AI81CC.tmp\Setup\AcSetup.dll
2014/3/24:12:53:18 Cam CAM-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/3/24:12:53:18 Cam CAM-PC PageOpen LaunchDialog
2014/3/24:12:53:29 Cam CAM-PC PageOpen LicenseDialog
2014/3/24:12:53:29 Cam CAM-PC PageOpen ProductInfoDialog
2014/3/24:12:53:29 Cam CAM-PC PageOpen ProductSelectionDialog2
2014/3/24:12:53:36 Cam CAM-PC PageOpen FullProgressDialog
2014/3/24:12:53:38 Cam CAM-PC Download Skipped DOTNET4 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DOTNET4K...
2014/3/24:12:53:38 Cam CAM-PC Installing .NET Framework Runtime 4.0: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe" /q
2014/3/24:13:00:49 Cam CAM-PC Install .NET Framework Runtime 4.0 Succeeded
2014/3/24:13:00:49 Cam CAM-PC Download Skipped DOTNET4KB2468871 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DOTNET4K...
2014/3/24:13:00:49 Cam CAM-PC Installing .NET Framework Runtime 4.0 KB2468871: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe" /q /norestart
2014/3/24:13:03:14 Cam CAM-PC Install .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1603
2014/3/24:13:03:14 Cam CAM-PC Rollback .NET Framework Runtime 4.0 Failed Installation aborted, Result=1619
and
which are identical as far as I can tell.
Can you try running that .net framework update directly. According to the log the file path is C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe
Just double click that EXE "DP40-KB2468871-v2-x64.exe" and let us know what the error says. Also .what version of Microsoft .net framework is currently installed on your system?
I currently have .Net framework 4, and this is what shows when trying to click on that exe:
and it's long but this is what the log file says:
Loading localized engine data for language 1033 from C:\2eb3a8b30fdbfd27c5c0be4b0944d6\1033\LocalizedData.xml
OpenFileMapping fails with last error: 6
The handle to the section is Null
evaluating ApplicableIf:
evaluating IsPresent:
Summary Information:
WM_ACTIVATEAPP: Focus stealer's windows WAS visible, NOT taking back focus
Successfuly found file C:\2eb3a8b30fdbfd27c5c0be4b0944d6\1033\EULA.rtf
Launching Download and Install operations simultaneously.
Starting install of item 'NDP40-KB2468871' at tickCount = 21594001
calling PerformAction on an installing performer
Final Result: Installation failed with error code: (0x80070643), "Fatal error during installation. " (Elapsed time: 0 00:01:38).
