Installation & Licensing
AutoCAD 2014 Invalid Configuration Path
4 REPLIES 4
earm89
3068 Views, 4 Replies
Hi guys, I'm trying to use AutoCAD 2014 and I've already installed it 2 times but I keep getting an AutoCAD Error Aborting message.
It says
FATAL ERROR: Invalid Configuration path\filename:
C:\Users\XXXXfolder\AppData\Local\Autodesk\AutoCAD 2014\R19.1\enu\
And then the program crashes, I've sent the report many times and already did the suggested corrections.
I'm using Win8 and already tried the win7 compatibility mode, run as an administrator and everything but isn't working at all.
I need this for my thesis so please guys any help will be appreciate.
Enrique Ros.
4 REPLIES 4
TravisNave
in reply to: earm89
Welcome to the community.  Make sure you are installing with local admin rights and that your UAC for that user is disabled, as well as anti-virus off.
Traverse to that path and make sure it exists and that you have access to it.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
dembkod
in reply to: earm89
David Dembkoski
dembkod
in reply to: earm89
earm89,
Hello. Has this ever worked for you? Is this new behavior?
You look like you are having some sort of an issue with your profile folder. Can you try to use the “Reset to Defaults” option from the Windows Metro interface? You should not need compatibility mode.
Thank you for taking part in our community!
David Dembkoski
earm89
in reply to: dembkod
Hey guys! I just manage to open the program.
I looked down the folder and didn't had permission to it so after granting myself permision to the "...\AppData\Local\Autodesk" file I was able to run AutoCAD without any problems.
Thanks for your help and I hope this works if someone else have this problem. Now I'm off to work with it!
Thanks again.
E. Ros
Administrator Productivity
