Installation & Licensing
Active Contributor
r.ernstberger
Message 1 of 2 (1,101 Views)
AutoCAD 2013 won't start on XP 32
1101 Views, 1 Replies
06-04-2012 04:08 AM
Hi all,
i've installed AutoCAD Mechanical 2013 on 2 machines with German Windows XP 32 bit.
There are all security patches installed (including the optional ones) and I also have the latest NVIDIA display drivers. .NET 4 is also installed and seems to work..
Installation and licensing worked fine, Fusion 2013 works also.
But AutoCAD 2013 won't start (regardless if plain AutoCAD or Mechanical).
Somewhere at the time where the welcome screen is displayed i get a endless chain of error messages (have to kill acad.exe with the task manager).
One of the error dialogs offers some information:
Die Anwendung unterstützt kein JIT-Debuggen.
Weitere Informationen finden Sie am Ende dieser Meldung.
************** Ausnahmetext **************
System.IO.FileLoadException: Eine von "AmMgdInterop.dll" importierte Prozedur konnte nicht geladen werden.
Dateiname: "AmMgdInterop.dll"
   bei Autodesk.AutoCADM.Ribbon.MechanicalBrowserRibbonToggleButton.get_IsPressed()
   bei Autodesk.AutoCADM.Ribbon.RibbonToggleButton.OnApplicationIdle(Object sender, EventArgs e)
   bei System.EventHandler.Invoke(Object sender, EventArgs e)
   bei Autodesk.AutoCAD.ApplicationServices.Core.Application.raise_Idle(Object value0, EventArgs value1)
   bei Autodesk.AutoCAD.ApplicationServices.Core.Application.OnIdle()
************** Geladene Assemblys **************
mscorlib
    Assembly-Version: 4.0.0.0.
    Win32-Version: 4.0.30319.269 (RTMGDR.030319-2600).
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll.
Acdbmgd
    Assembly-Version: 19.0.0.0.
    Win32-Version: 19.0.55.0.0.
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/AcdbMgd.DLL.
System
    Win32-Version: 4.0.30319.269 built by: RTMGDR.
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll.
System.Core
    Win32-Version: 4.0.30319.233 built by: RTMGDR.
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll.
AdApplicationFrame
    Assembly-Version: 0.0.0.0.
    Win32-Version: 3.5.19.0.
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/AdApplicationFrame.DLL.
AdWindows
    Assembly-Version: 3.5.21.0.
    Win32-Version: 3.5.21.0.
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/AdWindows.DLL.
PresentationFramework
    Win32-Version: 4.0.30319.275.
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll.
WindowsBase
    Win32-Version: 4.0.30319.275 built by: RTMGDR.
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll.
PresentationCore
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll.
System.Xaml
    Win32-Version: 4.0.30319.1 built by: RTMRel.
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll.
AdWindows.resources
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/de-DE/AdWindows.resources.DLL.
System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll.
PresentationFramework.Classic
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Classic/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Classic.dll.
System.Drawing
    Win32-Version: 4.0.30319.276 built by: RTMGDR.
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
PresentationCore.resources
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationCore.resources/v4.0_4.0.0.0_de_31bf3856ad364e35/PresentationCore.resources.dll.
accoremgd
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/accoremgd.DLL.
Acmgd
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/Acmgd.DLL.
System.Configuration
    Win32-Version: 4.0.30319.1 (RTMRel.030319-0100).
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll.
AcWindows
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/AcWindows.DLL.
mscorlib.resources
    Win32-Version: 4.0.30319.235 (RTMGDR.030319-2300).
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_de_b77a5c561934e089/mscorlib.resources.dll.
PresentationFramework.resources
    Win32-Version: 4.0.30319.1.
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.resources/v4.0_4.0.0.0_de_31bf3856ad364e35/PresentationFramework.resources.dll.
AcCui
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/AcCui.DLL.
PresentationFramework.Aero
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll.
WindowsFormsIntegration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll.
AmWindows
    Assembly-Version: 14.0.0.0.
    Win32-Version: 17.0.48.0.0.
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/acadm/amwindows.dll.
AmWindows.resources
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/acadm/de-DE/AmWindows.resources.DLL.
AcWindows.resources
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/de-DE/AcWindows.resources.DLL.
PresentationUI
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll.
PresentationUI.resources
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationUI.resources/v4.0_4.0.0.0_de_31bf3856ad364e35/PresentationUI.resources.dll.
System.Xml.Linq
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll.
AmMgdInteropReverse
    Assembly-Version: 17.0.0.0.
    CodeBase: file:///D:/autodesk/autocad%202013/acadm/AmMgdInteropReverse.dll.
AmRibbon
    CodeBase: file:///D:/autodesk/autocad%202013/acadm/AmRibbon.DLL.
System.Web
    Win32-Version: 4.0.30319.272 built by: RTMGDR.
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll.
AcFusion
    Assembly-Version: 1.0.4413.25327.
    Win32-Version: 0.2.0.230.
    CodeBase: file:///c:/programme/autodesk/applicationplugins/fusionplugin2013.bundle/contents/win32/acfusion.arx.
AcFusionRes
    Assembly-Version: 0.2.0.230.
    CodeBase: file:///C:/Programme/Autodesk/ApplicationPlugins/FusionPlugin2013.bundle/Contents/Win32/AcFusionRes.dll.
AcFusionRes.resources
    CodeBase: file:///C:/Programme/Autodesk/ApplicationPlugins/FusionPlugin2013.bundle/Contents/Win32/de-DE/AcFusionRes.resources.DLL.
ContextualTabSelectorRules
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/AcWindows.dll.
AmContextualTabSelectorRules
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/acadm/amcontextualtabselectorrules.dll.
System.Windows.Forms
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
ManagedMC3
    Assembly-Version: 6.4.0.0.
    Win32-Version: 6.4.0.0.
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/ManagedMC3.DLL.
AmRibbon.resources
    CodeBase: file:///D:/autodesk/autocad%202013/acadm/de-DE/AmRibbon.resources.DLL.
System.Xaml.resources
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Xaml.resources.dll.
AcCommandToolTips
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/AcCommandToolTips.DLL.
AcCommandTooltips.resources
    Win32-Version: 19.0.0.0.
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/de-DE/AcCommandToolTips.resources.DLL.
AmCommandToolTips
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/acadm/amcommandtooltips.dll.
AmCommandToolTips.resources
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/acadm/de-DE/AmCommandToolTips.resources.DLL.
AcLivePreviewContext
AcLayer
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/AcLayer.DLL.
AcLayer.resources
    CodeBase: file:///D:/Autodesk/AutoCAD%202013/de-DE/AcLayer.resources.DLL.
System.Windows.Forms.resources
    Win32-Version: 4.0.30319.235 built by: RTMGDR.
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
************** JIT-Debuggen **************
Die Anwendung unterstützt kein JIT-Debuggen für Windows Forms.
Weitere Informationen erhalten Sie vom Autor
der Anwendung.
Parts of the informatiuon is in German, but the general complaint seems to be about AmMgdInterop.dll.
Are there any issues known about this DLL or has anyone else seen similar errors?
Richard
New Member
bangell1
Message 2 of 2 (592 Views)
Re: AutoCAD 2013 won't start on XP 32
12-22-2012 08:16 AM in reply to: r.ernstberger
I have the exact same error when Mechanical is launched.  I have Autodesk Product design suite 2013. Autocad Mechanical is the only application that gives the error. All other applications in the suite launch and work fine. This is a fresh install, first time AutoCad on this machine.
XP, 32bit
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
