• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Contributor
    AutoCAD 2013 won't start on XP 32
    765 Views, 1 Replies
    06-04-2012 04:08 AM
    Hi all,
    i've installed AutoCAD Mechanical 2013 on 2 machines with German Windows XP 32 bit.
    There are all security patches installed (including the optional ones) and I also have the latest NVIDIA display drivers. .NET 4 is also installed and seems to work..
    Installation and licensing worked fine, Fusion 2013 works also.
    But AutoCAD 2013 won't start (regardless if plain AutoCAD or Mechanical).
    Somewhere at the time where the welcome screen is displayed i get a endless chain of error messages (have to kill acad.exe with the task manager).
    One of the error dialogs offers some information:
    Die Anwendung unterstützt kein JIT-Debuggen.
    Weitere Informationen finden Sie am Ende dieser Meldung.
    ************** Ausnahmetext **************
    System.IO.FileLoadException: Eine von "AmMgdInterop.dll" importierte Prozedur konnte nicht geladen werden.
    Dateiname: "AmMgdInterop.dll"
       bei Autodesk.AutoCADM.Ribbon.MechanicalBrowserRibbonToggleButton.get_IsPressed()
       bei Autodesk.AutoCADM.Ribbon.RibbonToggleButton.OnApplicationIdle(Object sender, EventArgs e)
       bei System.EventHandler.Invoke(Object sender, EventArgs e)
       bei Autodesk.AutoCAD.ApplicationServices.Core.Application.raise_Idle(Object value0, EventArgs value1)
       bei Autodesk.AutoCAD.ApplicationServices.Core.Application.OnIdle()
    ************** Geladene Assemblys **************
    mscorlib
        Assembly-Version: 4.0.0.0.
        Win32-Version: 4.0.30319.269 (RTMGDR.030319-2600).
        CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll.
    Acdbmgd
        Assembly-Version: 19.0.0.0.
        Win32-Version: 19.0.55.0.0.
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/AcdbMgd.DLL.
    System
        Win32-Version: 4.0.30319.269 built by: RTMGDR.
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll.
    System.Core
        Win32-Version: 4.0.30319.233 built by: RTMGDR.
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll.
    AdApplicationFrame
        Assembly-Version: 0.0.0.0.
        Win32-Version: 3.5.19.0.
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/AdApplicationFrame.DLL.
    AdWindows
        Assembly-Version: 3.5.21.0.
        Win32-Version: 3.5.21.0.
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/AdWindows.DLL.
    PresentationFramework
        Win32-Version: 4.0.30319.275.
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll.
    WindowsBase
        Win32-Version: 4.0.30319.275 built by: RTMGDR.
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll.
    PresentationCore
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll.
    System.Xaml
        Win32-Version: 4.0.30319.1 built by: RTMRel.
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll.
    AdWindows.resources
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/de-DE/AdWindows.resources.DLL.
    System.Xml
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll.
    PresentationFramework.Classic
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Classic/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Classic.dll.
    System.Drawing
        Win32-Version: 4.0.30319.276 built by: RTMGDR.
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
    PresentationCore.resources
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationCore.resources/v4.0_4.0.0.0_de_31bf3856ad364e35/PresentationCore.resources.dll.
    accoremgd
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/accoremgd.DLL.
    Acmgd
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/Acmgd.DLL.
    System.Configuration
        Win32-Version: 4.0.30319.1 (RTMRel.030319-0100).
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll.
    AcWindows
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/AcWindows.DLL.
    mscorlib.resources
        Win32-Version: 4.0.30319.235 (RTMGDR.030319-2300).
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_de_b77a5c561934e089/mscorlib.resources.dll.
    PresentationFramework.resources
        Win32-Version: 4.0.30319.1.
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.resources/v4.0_4.0.0.0_de_31bf3856ad364e35/PresentationFramework.resources.dll.
    AcCui
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/AcCui.DLL.
    PresentationFramework.Aero
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll.
    WindowsFormsIntegration
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll.
    AmWindows
        Assembly-Version: 14.0.0.0.
        Win32-Version: 17.0.48.0.0.
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/acadm/amwindows.dll.
    AmWindows.resources
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/acadm/de-DE/AmWindows.resources.DLL.
    AcWindows.resources
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/de-DE/AcWindows.resources.DLL.
    PresentationUI
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll.
    PresentationUI.resources
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationUI.resources/v4.0_4.0.0.0_de_31bf3856ad364e35/PresentationUI.resources.dll.
    System.Xml.Linq
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll.
    AmMgdInteropReverse
        Assembly-Version: 17.0.0.0.
        CodeBase: file:///D:/autodesk/autocad%202013/acadm/AmMgdInteropReverse.dll.
    AmRibbon
        CodeBase: file:///D:/autodesk/autocad%202013/acadm/AmRibbon.DLL.
    System.Web
        Win32-Version: 4.0.30319.272 built by: RTMGDR.
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll.
    AcFusion
        Assembly-Version: 1.0.4413.25327.
        Win32-Version: 0.2.0.230.
        CodeBase: file:///c:/programme/autodesk/applicationplugins/fusionplugin2013.bundle/contents/win32/acfusion.arx.
    AcFusionRes
        Assembly-Version: 0.2.0.230.
        CodeBase: file:///C:/Programme/Autodesk/ApplicationPlugins/FusionPlugin2013.bundle/Contents/Win32/AcFusionRes.dll.
    AcFusionRes.resources
        CodeBase: file:///C:/Programme/Autodesk/ApplicationPlugins/FusionPlugin2013.bundle/Contents/Win32/de-DE/AcFusionRes.resources.DLL.
    ContextualTabSelectorRules
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/AcWindows.dll.
    AmContextualTabSelectorRules
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/acadm/amcontextualtabselectorrules.dll.
    System.Windows.Forms
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
    ManagedMC3
        Assembly-Version: 6.4.0.0.
        Win32-Version: 6.4.0.0.
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/ManagedMC3.DLL.
    AmRibbon.resources
        CodeBase: file:///D:/autodesk/autocad%202013/acadm/de-DE/AmRibbon.resources.DLL.
    System.Xaml.resources
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Xaml.resources.dll.
    AcCommandToolTips
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/AcCommandToolTips.DLL.
    AcCommandTooltips.resources
        Win32-Version: 19.0.0.0.
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/de-DE/AcCommandToolTips.resources.DLL.
    AmCommandToolTips
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/acadm/amcommandtooltips.dll.
    AmCommandToolTips.resources
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/acadm/de-DE/AmCommandToolTips.resources.DLL.
    AcLivePreviewContext
    AcLayer
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/AcLayer.DLL.
    AcLayer.resources
        CodeBase: file:///D:/Autodesk/AutoCAD%202013/de-DE/AcLayer.resources.DLL.
    System.Windows.Forms.resources
        Win32-Version: 4.0.30319.235 built by: RTMGDR.
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
    ************** JIT-Debuggen **************
    Die Anwendung unterstützt kein JIT-Debuggen für Windows Forms.
    Weitere Informationen erhalten Sie vom Autor
    der Anwendung.
    Parts of the informatiuon is in German, but the general complaint seems to be about AmMgdInterop.dll.
    Are there any issues known about this DLL or has anyone else seen similar errors?
    Richard
    Please use plain text.
    New Member
    Re: AutoCAD 2013 won't start on XP 32
    12-22-2012 08:16 AM in reply to: r.ernstberger
    I have the exact same error when Mechanical is launched.  I have Autodesk Product design suite 2013. Autocad Mechanical is the only application that gives the error. All other applications in the suite launch and work fine. This is a fresh install, first time AutoCad on this machine.
    XP, 32bit
