Installation & Licensing
AutoCAD 2013 Architecture / Instalation failure (1603, 1619)
1 REPLY 1
727 Views, 1 Reply
Hello
I am trying to install AutoCAD Arhitecture 2013 on my computer (Windows 7 64 bit) but every time it failed. I also tried many with many solutions on Autodesk Forums, but none was succesfull. I already have installed Autocad 2013 and 3d s Max Design 2013 - both educational.
2012/12/7:17:28:12 Danijel DANIJEL-PC === Setup started on DANIJEL-PC by Danijel ===
2012/12/7:17:28:12 Danijel DANIJEL-PC Launch
2012/12/7:17:28:26 Danijel DANIJEL-PC PageOpen LaunchDialog
2012/12/7:17:28:29 Danijel DANIJEL-PC PageOpen LicenseDialog
2012/12/7:17:28:32 Danijel DANIJEL-PC PageOpen ProductInfoDialog
2012/12/7:17:29:49 Danijel DANIJEL-PC PageOpen ProductSelectionDialog2
2012/12/7:17:30:00 Danijel DANIJEL-PC PageOpen FullProgressDialog
2012/12/7:17:30:01 Danijel DANIJEL-PC Installing .NET Framework Runtime 4.0: C:\Users\Danijel\Desktop\AUTODESK.AUTOCAD.ARCHITECTURE.V2013.WIN64-ISO\aca2013_x64\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2012/12/7:17:38:46 Danijel DANIJEL-PC Install .NET Framework Runtime 4.0 Succeeded
2012/12/7:17:38:46 Danijel DANIJEL-PC Installing .NET Framework Runtime 4.0 KB2468871: C:\Users\Danijel\Desktop\AUTODESK.AUTOCAD.ARCHITECTURE.V2013.WIN64-ISO\aca2013_x64\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2012/12/7:17:47:52 Danijel DANIJEL-PC Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2012/12/7:17:47:52 Danijel DANIJEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\Danijel\Desktop\AUTODESK.AUTOCAD.ARCHITECTURE.V2013.WIN64-ISO\aca2013_x64\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2012/12/7:17:48:05 Danijel DANIJEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2012/12/7:17:48:05 Danijel DANIJEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Users\Danijel\Desktop\AUTODESK.AUTOCAD.ARCHITECTURE.V2013.WIN64-ISO\aca2013_x64\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2012/12/7:17:48:15 Danijel DANIJEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2012/12/7:17:48:15 Danijel DANIJEL-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Users\Danijel\Desktop\AUTODESK.AUTOCAD.ARCHITECTURE.V2013.WIN64-ISO\aca2013_x64\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\Danijel\AppData\Local\Temp\vcredist_x86_2010.log
2012/12/7:17:48:24 Danijel DANIJEL-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2012/12/7:17:48:24 Danijel DANIJEL-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Users\Danijel\Desktop\AUTODESK.AUTOCAD.ARCHITECTURE.V2013.WIN64-ISO\aca2013_x64\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\Danijel\AppData\Local\Temp\vcredist_x64_2010.log
2012/12/7:17:48:35 Danijel DANIJEL-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2012/12/7:17:48:35 Danijel DANIJEL-PC Installing DirectX Runtime: C:\Users\Danijel\Desktop\AUTODESK.AUTOCAD.ARCHITECTURE.V2013.WIN64-ISO\aca2013_x64\3rdParty\DirectX\DXSETUP.exe /silent
2012/12/7:17:49:45 Danijel DANIJEL-PC Install DirectX Runtime Succeeded
2012/12/7:17:49:45 Danijel DANIJEL-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Danijel\Desktop\AUTODESK.AUTOCAD.ARCHITECTURE.V2013.WIN64-ISO\aca2013_x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/7:17:50:17 Danijel DANIJEL-PC Install FaroSDK Succeeded
2012/12/7:17:50:23 Danijel DANIJEL-PC Installing AutoCAD® Architecture 2013: TRANSFORMS="C:\Users\Danijel\Desktop\AUTODESK.AUTOCAD.ARCHITECTURE.V2013.WIN64-ISO\aca2013_x64\x64\en-us\ACA\ACA.mst;C:\Users\Danijel\AppData\Local\Temp\_AIE97B.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Danijel\Desktop\AUTODESK.AUTOCAD.ARCHITECTURE.V2013.WIN64-ISO\aca2013_x64\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/7:17:56:16 Danijel DANIJEL-PC Install AutoCAD® Architecture 2013 Failed Installation aborted, Result=1603
2012/12/7:17:56:24 Danijel DANIJEL-PC Rollback FaroSDK Succeeded
2012/12/7:17:56:24 Danijel DANIJEL-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/12/7:17:56:24 Danijel DANIJEL-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2012/12/7:17:56:25 Danijel DANIJEL-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2012/12/7:17:56:25 Danijel DANIJEL-PC Rollback .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1619
2012/12/7:17:56:25 Danijel DANIJEL-PC Rollback .NET Framework Runtime 4.0 Failed Installation aborted, Result=1619
I will be very grateful for solution!
Danijel
1 REPLY 1
dembkod
Danijel
You could have incompatible C++ on your system , or other blocks. Do you have other AutoCAD 2013 verticals on your system? AutoCAD, MEP? Do they have any service packs installed? If so, uninstall the service packs and retry your architecture installation. You can install the Service packs again after. We have found the install of the service packs may block some machines.
If removing the service packs does not help, uninstall your C++ entries and your NET entries from your system. The installer will replace them on install.
Thank you for taking part in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
Administrator Productivity
