Installation & Licensing
AutoCAD 2012LT Tries to start then at flash screen shuts down
3 REPLIES 3
889 Views, 3 Replies
I installed 2012LT on a HP4430s with Win7 64bit, 4GB memory, Intel CORE i3-2310M CPU @ 2.10GHz & Intel HD Graphics Family Video Card. Started and ran fine for about 2 weeks, then I got a blue screen and have not been able to get it to run since. I have uninstalled (complete including registry); repair; reinstalling in safe mode; removing FLEXnet file; resetting AutoCAD 2012LT settings to default and the same thing happens when I start the program, it appears to load then as it should flash to full screen it does for less than a second then shuts down. Does anyone else have this problem or know of a fix for it? I started with AutoCAD Lt 15 years ago and have upgraded every couple of versions and have never had this kind of problem. Any suggestions or help would be greatly appreciated.
3 REPLIES 3
Charles_Shade
Any Norton products on the system?
TravisNave
Did you delete your ProductInfomation.pit file as well?  Probably a corrupted license.
Autodesk Forums:
emily.xu
Could you please find and upload the startup log file with .log extension located in folder C:\ProgramData\Autodesk\AdLM for research?
Emily Xu
Product Support
Administrator Productivity
