• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    kchilders
    AutoCAD 2012 resolution problems
    5922 Views, 9 Replies
    05-26-2011 02:50 PM
    My problem is that everytime I launch AutoCAD 2012 I get an error message stating that "AutoCAD requires a 1024 X 768 resolution or higher" (or something to that effect) and when it loads, AutoCAD is not properly sized to fit my screen.  It has some giant sized control tabs across the top and a very small working area.  Maximizing it causes about half of the program window to be lost off the side of my screen, and manually dragging the edges of the window to size it doesn't help.  Basically, it's unusable right now.
    My specs are:
    42" 1080p screen (16:9)
    Windows 7 64-bit
    AMD Phenom II X2 3.2 GHz
    6 GB RAM
    ATI Radeon HD 5770 w/ 1GB video RAM
    Does anyone know what's wrong or how to fix it?  Thanks.
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: AutoCAD 2012 resolution problems
    05-26-2011 03:00 PM in reply to: kchilders
    What is your screen resolution set to?
    New Member
    kchilders
    06-02-2011 05:52 PM in reply to: TravisNave
    1920 X 1080
    *Expert Elite*
    TravisNave
    06-03-2011 08:55 AM in reply to: kchilders
    That *should* work.  You might as a test just set your resolution to 1024x768 (though it will look terrible on your display) then launch AutoCAD successfully.  At that point, change your resolution back and see if it continues to work.  Good luck!
    Edit:  I also tried searching for a certified and tested driver for your video card and setup, and this is what was displayed from Autodesk:
    The combination of your selections is either not supported or has not been tested by Autodesk.
    New Member
    asayyar
    09-06-2011 10:56 AM in reply to: TravisNave
    Having the same problem with 2012 LT version ! using win7, 64-bit. tried lowering the screen resolution but it doesn't work. there was no error while installing thou. when I hit any of top- tabs ( Open;for instance) the reolution of pop up seems to be correct!
    when i try :Right click>options> "Use large buttons for toolbar" checked or unchecked, their sizes are the same!!!
    Any clue?
    asayyar.
    New Member
    asayyar
    09-07-2011 02:47 PM in reply to: asayyar
    One Soultion:
    as a try, I changed the Monitor's color ( in Right click or Display>screen resolution> Monitor Tab>colors) from 32bit to 16 and it looks much better. even thought i have to do it each time I open CAD.
    Distinguished Contributor
    09-19-2011 01:34 PM in reply to: asayyar
    I'm having the same problem with this system:
    It makes AutoCAD too big to fit on the screen, with giant icons,looking like it's at a very low resolution
    AutoCAD 2012
    Windows 7 64 bit
    i3 Intel processor
    8gb RAM
    NVIDIA GeForce GTX 560 video
    24" monitor at 1680 x 1050 resolution
    Same message "Error Aborting-  AutoCAD requires 1024 x 758 to run...
    David
    New Member
    clarivel.campa001
    10-21-2011 07:45 AM in reply to: kchilders
    Hi there.
    I hope I'm not too late to help you.  I just downloaded it and had the same problem.  But upon searching in the "help feature" in the pogram itself, it suggests that you may need to change the DPI to 96% on your computer setting.  I wasn't sure where I could find that, but after searching in my main "start" window, it led me right to it.   After I did it on mine, it turned out fine.  With the exception that the font and letters are way too small for my eyesight.  What I did to compensate that in my case is that I turned on the magnifying glass in my computer setting, so that whatever area my mouse hovers over is enlarged.
    Hope this helps.:womanhappy:
    Active Contributor
    02-09-2012 02:12 PM in reply to: clarivel.campa001
    Folks,
    I just completed a support ticket for which a client reported the error, “AutoCAD requires 1024 by 768 resolution or higher to run”. The graphics card meets the system requirements, but Windows Display Magnification was set to 150%.
    Once we changed Display Magnification to 100%, the error did not appear when starting AutoCAD.
    To change the setting in Windows 7:
    1. Close all applications; a log-off will be required
    2. RMB on the desktop > Personalize > Display (lower corner of dialog box)
    3. Select Smaller - 100% > Apply > Log off now
    4. Login and test AutoCAD
    I hope this information was helpful.
    Best regards,
    Jerry
    New Member
    04-08-2012 08:43 PM in reply to: kchilders
    Spoiler
    Spoiler
    Spoiler
    :smileyhappy:Thank God and Thank you ~ the problem made me crazy....
