• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    lorne.bruce
    AutoCAD 2012 Trial Startup Problem
    617 Views, 14 Replies
    02-07-2012 10:19 AM
    Does anyone know how to resolve the issue I'm having with my trial version of AutoCAD 2012? I downloaded it yesterday, played around for about an hour and went to bed...this morning it refuses to load, stopping at the "Your Autodesk Trial" page and refusing to let me click the top right "Use AutoCAD" button without sending up an error message:
    An error has occurred in the script on this page.
    Line: 1
    Char: 52
    Error: Unterminated string constant
    Code: 0
    URL: https://ipm.autodesk.com/ipm/acd/2012/enu/index.html?redirected=1&d=29&country=ca
    Below that it asks if I want to continue running scripts on this page. If I click "Yes" I'm directed to a web page that can't be opened (http://localhost/action=LocalRun) and if I click "No" nothing happens and I remain stuck at the "Your Autodesk Trial" page. I need to get familiar with this program, and only have this 30 day window in which to do it, so I'm a little anxious to make the most of it. Thanks for your help!
    Product Support
    byron.morales
    Re: AutoCAD 2012 Trial Startup Problem
    02-08-2012 04:34 PM in reply to: lorne.bruce
    Hello:
    Please try the following:
    Turn of  UAC (user account control)  - you do this by;
                    going to the Control Panel
                    and selecting User Accounts
                    and then selecting Change User Account Control Settings
                    move to the bottom as never notify and pressing Ok
    Reboot computer
    Now Right click on the AutoCAD 2012 Icon and select Run as Administrator
    Let me know if the above helps resolve the problem.
    Byron Morales
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution:smileywink:
    ***Guru
    TravisNave
    02-09-2012 07:52 AM in reply to: lorne.bruce
    In addition, you might make sure that your Internet Explorer is up-to-date and set as your default browser.
    Can you click that link directly and open the site?
    My Top Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files | Search Autodesk Discussion Groups
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Member
    fatfingers
    02-09-2012 01:05 PM in reply to: TravisNave
    Can you get one of the autodesk web guys to update line 22 on this page: https://ipm.autodesk.com/ipm/acd/2012/enu/index.html?redirected=1&d=30&country=us
    to terminate the string constant.
    The code in question is this:
    setTimeout("mboxUpdate('itm_nurture_convert','type=use-autocad )",300);
        ^ right here string terminator is missing.
    ***Guru
    TravisNave
    02-09-2012 01:20 PM in reply to: fatfingers
    It does appear that there is a typo on the script on line 22, as I have confirmed by viewing the source.
    If you turn off your script debugging in the advanced options of Internet Explorer, you should be able to safely ignore this issue.  Doing so allows the page to load properly for me.
    Member
    fatfingers
    02-09-2012 01:28 PM in reply to: TravisNave
    I have script debugging disabled. I am running XP sp3 with IE8 as admin, so is there another solution to get the trial to run?
    ***Guru
    TravisNave
    02-09-2012 01:38 PM in reply to: fatfingers
    I'm on Windows 7 running IE9, so maybe that is why.  You cannot just launch the software and use it regardless of that box?
    Member
    fatfingers
    02-09-2012 01:51 PM in reply to: TravisNave
    When I start Acad I get the same problem as the OP.  The script that is supposed to run when the Use AutoCAD button is pushed craps out with the same error as in th OP.  I then have to force close both acad.exe and LMU.exe.  I was under the impression, based on the script error, that the typo on the page I referred to before was some how not allowing me to run the script which in turn started the program.
    ***Guru
    TravisNave
    02-09-2012 01:52 PM in reply to: fatfingers
    Crazy thought, but unzip this corrected index.html file onto your desktop.  Then in the root of your Windows User Profile under your username create a folder called enu and paste the file there too.  Then run the one on your Desktop and allow active content when prompted.  Then replace the redirect line with this one:  ?redirected=1&d=30&country=us  and hit enter.  This allowed me to click the run link.  Might work for you too.
    Member
    fatfingers
    02-09-2012 02:17 PM in reply to: TravisNave
    Ok I did what you asked.  I have to click on the index.html first, allow active content, then start AutoCAD then wait for another LMU.exe page to display (shows tutorials whith the run autocad button in the right hand corner) then click that run button.
    So in short the software is running now.  Abit of a round about way to start it though.
