Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
AutoCAD 2012 License Error [-15.570.0 ]
- Highlight
- Email to a Friend
Dear all,
I have installed AutoCAD 2012 as a network license installation on all client PC. The server is not on a domain but is on a workgroup called WORKGROUP.
On this server the FlexLM is installed and running fine with valid license detected. The server has Windows Server 2008 - 32 bit.
The client PCs are also not on any domain, but belong to workgroup WORKGROUP. Windows 7 business is installed on all client PCs. AutoCAD was installed from a deplyment created on this same folder.
When I start AutoCAD 2012 on client PCs, I get an error as Error [-15.570.0]
I have tried below:
1
Ping from the Client PCs to the server using Ping Hostname is successful, however in the ping results - pinging from ... does not have the ip addres in a normal format as "000.000.0.000" but in a strange format. This includes numbers and alphabets.
Ping with IP address give successful result with pinging from ... result showing correct server ip address in normal format.
2
Since windows firewall is enabled on server and clients , I have configured exception on port 2080 on both. Windows Server 2008 (added exception to port 2080) and Windows 7 (added rules inbound & outbound to port 2080 - allowed communicaltion)
I need to know if the Autodesl FlexLM works in a non domain configured network? And what else should I try to fix this issue?
Thank you to all for your suggestions and support
Best Regards,
NEIL
Re: AutoCAD 2012 License Error [-15.570.0 ]
- Highlight
- Email to a Friend
try installing this license manager for server 2008: http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
it doesn't matter if its on a domain or not if the clients can ping the server by host name you should be fine
- Highlight
- Email to a Friend
IPv6 connectivity between Windows 7 and Server 2008 is the culprit here. For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensi
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: AutoCAD 2012 License Error [-15.570.0 ]
- Highlight
- Email to a Friend
On the client machine, try this... Look at the image.
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
I am having the same problem on all remote machines. I have the network lic tool loaded on a windows 7 pc 64bit system. I can run autocad from the host pc and the LMHOST tool shows lic are available and can be issued. When I attempt to connect from any other machine I am prompeted for the directory of the lic file, which we can find via browsing for it. Then we are prompeted for with the [-15.570.0] error message.
- Highlight
- Email to a Friend
did you try the above solutions?
- Highlight
- Email to a Friend
u have to start autocad as admin when u start it first time. this is the best solition
- Highlight
- Email to a Friend
In addition to adding exception port 2080, add exception to ports 2000-27009 as well.
Hope this helps.
Timmy De Austria
Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution.
- Highlight
- Email to a Friend
I had the same problem. After trying out everything here to no avail, I finally succeeded by totally uninstalling the license manager, and reinstalling it directly from the main autocad installer, tools section. I dont know why it worked, but it did!
