Installation & Licensing
Valued Contributor
neil.fernandes
Message 1 of 11 (25,488 Views)
AutoCAD 2012 License Error [-15.570.0]
25488 Views, 10 Replies
06-29-2011 07:12 AM
Dear all,
I have installed AutoCAD 2012 as a network license installation on all client PC. The server is not on a domain but is on a workgroup called WORKGROUP.
On this server the FlexLM is installed and running fine with valid license detected. The server has Windows Server 2008 - 32 bit.
The client PCs are also not on any domain, but belong to workgroup WORKGROUP. Windows 7 business is installed on all client PCs. AutoCAD was installed from a deplyment created on this same folder.
When I start AutoCAD 2012 on client PCs, I get an error as Error [-15.570.0]
I have tried below:
1
Ping from the Client PCs to the server using Ping Hostname is successful, however in the ping results - pinging from ... does not have the ip addres in a normal format as "000.000.0.000" but in a strange format. This includes numbers and alphabets.
Ping with IP address give successful result with pinging from ... result showing correct server ip address in normal format.
2
Since windows firewall is enabled on server and clients , I have configured exception on port 2080 on both. Windows Server 2008 (added exception to port 2080) and Windows 7 (added rules inbound & outbound to port 2080 - allowed communicaltion)
I need to know if the Autodesl FlexLM works in a non domain configured network? And what else should I try to fix this issue?
Thank you to all for your suggestions and support
Best Regards,
NEIL
DarrenP
Message 2 of 11 (25,482 Views)
Re: AutoCAD 2012 License Error [-15.570.0]
06-29-2011 07:14 AM in reply to: neil.fernandes
try installing this license manager for server 2008: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10976858&linkID=9240698
it doesn't matter if its on a domain or not if the clients can ping the server by host name you should be fine
TravisNave
Message 3 of 11 (25,471 Views)
06-29-2011 10:52 AM in reply to: neil.fernandes
IPv6 connectivity between Windows 7 and Server 2008 is the culprit here.  For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Active Member
sdewitt
Message 4 of 11 (25,134 Views)
08-04-2011 02:23 PM in reply to: neil.fernandes
On the client machine, try this...  Look at the image.
TravisNave
Message 5 of 11 (25,127 Views)
08-04-2011 02:42 PM in reply to: neil.fernandes
Timeout variable typically fixes latency issues. In this instance the issue is connectivity via IPv6 protocol. Modifying the client to point to the hostname via IPv4 resolves this issue, verified with a PING. Likely this older post has been resolved. Thanks for the input though.
New Member
tomm
Message 6 of 11 (22,525 Views)
12-07-2011 12:56 PM in reply to: neil.fernandes
I am having the same problem on all remote machines. I have the network lic tool loaded on a windows 7 pc 64bit system. I can run autocad from the host pc and the LMHOST tool shows lic are available and can be issued. When I attempt to connect from any other machine I am prompeted for the directory of the lic file, which we can find via browsing for it. Then we are prompeted for with the [-15.570.0] error message.
DarrenP
Message 7 of 11 (22,523 Views)
12-07-2011 01:02 PM in reply to: tomm
did you try the above solutions?
Active Member
Osi_turk
Message 8 of 11 (22,469 Views)
12-08-2011 08:02 PM in reply to: neil.fernandes
u have to start autocad as admin when u start it first time. this is the best solition
INACTIVE_Timmy.DeAustria
Message 9 of 11 (22,415 Views)
12-09-2011 05:51 PM in reply to: neil.fernandes
In addition to adding exception port 2080, add exception to ports 2000-27009 as well.
Hope this helps.
Timmy De Austria
Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
Active Member
RICHARDGILBERT6417
Message 10 of 11 (16,303 Views)
09-09-2012 06:06 AM in reply to: neil.fernandes
I had the same problem. After trying out everything here to no avail, I finally succeeded by totally uninstalling the license manager, and reinstalling it directly from the main autocad installer, tools section. I dont know why it worked, but it did!
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
