Installation & Licensing
AutoCAD 2012 LT Installation Problem
3 REPLIES 3
3ece
482 Views, 3 Replies
We are having problems installing 2012 LT on a few machines, it gets to the very end of install and then shows the msg on the attachment. It says 'installation complete. Some products failed to install'. The install does not finish because there is no way of opening the program. It has installed fine on other machines in the office.
This also happens with the full version of AutoCAD 2012 and this has also installed fine on other machines.
Anyone any ideas?
Many thanks in advance,
Stu.
3 REPLIES 3
david.lau
in reply to: 3ece
We will need the install log to get a better idea of what went wrong.
David Lau
3ece
in reply to: david.lau
Hi David,
How do I get the install log?
Stu.
3ece
in reply to: 3ece
David,
Hopefully this is what you were after and hopefully you can help...?
Many thanks,
Stuart.
Administrator Productivity
