Hi there,
I'm having a few problems trying to install AutoCAD 2012 on a clean XP machine.
It bombs out of the install halfway through and I get the below message..
Any suggestion you have would be greatly appreciated. See below for the log file.
Paul
The installation log file is:
2012/1/6:12:07:27 Administrator RSCA7175 === Setup started on RSCA7175 by Administrator === 2012/1/6:12:07:27 Administrator RSCA7175 Launch 2012/1/6:12:07:35 Administrator RSCA7175 PageOpen LaunchDialog 2012/1/6:12:08:56 Administrator RSCA7175 PageOpen LicenseDialog 2012/1/6:12:09:16 Administrator RSCA7175 PageOpen ProductInfoDialog 2012/1/6:12:09:27 Administrator RSCA7175 PageOpen ProductSelectionDialog2 2012/1/6:12:16:08 Administrator RSCA7175 PageOpen FullProgressDialog 2012/1/6:12:16:08 Administrator RSCA7175 Installing Autodesk® Design Review: TRANSFORMS="C:\DOCUME~1\ADMINI~1.RSC\LOCALS~1\Temp\_AI56.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/1/6:12:18:01 Administrator RSCA7175 Install Autodesk® Design Review Succeeded 2012/1/6:12:18:01 Administrator RSCA7175 Installing DirectX Runtime: D:\3rdParty\DirectX\DXSETUP.exe /silent 2012/1/6:12:18:09 Administrator RSCA7175 Install DirectX Runtime Succeeded 2012/1/6:12:18:09 Administrator RSCA7175 Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/1/6:12:18:20 Administrator RSCA7175 Install FaroSDK Succeeded 2012/1/6:12:18:20 Administrator RSCA7175 Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\DOCUME~1\ADMINI~1.RSC\LOCALS~1\Temp\_AI56.tmp\Media.mst"
2012/1/6:12:18:40 Administrator RSCA7175 Install Autodesk Material Library 2012 Succeeded 2012/1/6:12:18:40 Administrator RSCA7175 Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\DOCUME~1\ADMINI~1.RSC\LOCALS~1\Temp\_AI56.tmp\Media.mst"
2012/1/6:12:19:08 Administrator RSCA7175 Install Autodesk Material Library 2012 - Low Resolution Succeeded 2012/1/6:12:19:08 Administrator RSCA7175 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/1/6:12:19:21 Administrator RSCA7175 Install Autodesk Content Service Succeeded 2012/1/6:12:19:25 Administrator RSCA7175 Installing AutoCAD® 2012: TRANSFORMS="D:\x86\en-us\acad\acad.mst;C:\DOCUME~1\ADMINI~1.RSC\LOCALS~1\Temp\_AI56.tmp\x86\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/1/6:12:19:39 Administrator RSCA7175 Install AutoCAD® 2012 Failed Installation aborted, Result=1603 2012/1/6:12:19:46 Administrator RSCA7175 Rollback Autodesk Content Service Succeeded 2012/1/6:12:20:03 Administrator RSCA7175 Rollback Autodesk Material Library 2012 - Low Resolution Succeeded 2012/1/6:12:20:22 Administrator RSCA7175 Rollback Autodesk Material Library 2012 Succeeded 2012/1/6:12:20:22 Administrator RSCA7175 Rollback FaroSDK Succeeded 2012/1/6:12:20:23 Administrator RSCA7175 Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2012/1/6:12:20:36 Administrator RSCA7175 Rollback Autodesk® Design Review Succeeded
1603 is generic permission error, please try to install the software in diagnostics mode as described here
http://usa.autodesk.com/getdoc/id=TS75218
If the issue persists, please post the all the log files from the %temp% folder (start->run/search->type %temp% ->Enter) as a zip file.
