Installation & Licensing
AutoCAD 2011 will not install
1 REPLY 1
4183 Views, 1 Reply
I tried to install AutoCAD 2011, got 2 errors:
error 1904 Module C:\program files\common files\autodesk shared\DWF common\adview.dll failed to register. HRESULT-2147220473
Autodesk Material Library 2011 Base image library requires that Autodesk Material Library 2011 Base image library to be installed first.
Then shows that 3 items were not installed:
Autodesk design Review 2011
AutoCAD Mechanical 2011
Autodesk Vault 2011
Log file is as follows:
2010/6/12:13:00:34 Craig CRAIG-PC === Setup started on CRAIG-PC by Craig ===
2010/6/12:13:01:29 Craig CRAIG-PC === Setup ended ===
2010/6/12:13:01:09 Craig CRAIG-PC === Setup started on CRAIG-PC by Craig ===
2010/6/12:13:09:37 Craig CRAIG-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2010/6/12:13:14:44 Craig CRAIG-PC Install Autodesk Design Review 2011 Succeeded
2010/6/12:13:15:18 Craig CRAIG-PC Install DirectX 9.0 Runtime Succeeded
2010/6/12:13:15:44 Craig CRAIG-PC Install FARO LS 1.1.406.58 Succeeded
2010/6/12:13:17:05 Craig CRAIG-PC Install Autodesk Material Library 2011 Succeeded
2010/6/12:13:18:44 Craig CRAIG-PC Install Autodesk Material Library 2011 Base Image library Failed Installation aborted, Result=1603
2010/6/12:13:21:39 Craig CRAIG-PC Rollback Autodesk Material Library 2011 Succeeded
2010/6/12:13:21:41 Craig CRAIG-PC Rollback FARO LS 1.1.406.58 Succeeded
2010/6/12:13:21:42 Craig CRAIG-PC Rollback DirectX 9.0 Runtime Failed Failure is ignored, Result=1619
2010/6/12:13:22:12 Craig CRAIG-PC Rollback Autodesk Design Review 2011 Succeeded
2010/6/12:13:22:13 Craig CRAIG-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
Any help would be gratefully accepted.
Thank you
1 REPLY 1
hashim.mundol
Hi
Please try the suggestions in the folllowing forum post
http://forums.autodesk.com/t5/Autodesk-Design-Review/ADR-fails-to-register-2-dlls-on-install/m-p/266...
regssvr32 usage is here
http://support.microsoft.com/kb/249873
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Administrator Productivity
