• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    AutoCAD 2011 on VMware
    199 Views, 3 Replies
    11-29-2012 03:13 AM
    I' m an italian architect ,
    I have a server with windows vista with a VMware virtual machine with windows server 2003, in 2009 I bought a networking autocad licenze and the autocad autorized shop installed the licenze on my VMware machine, and everything was going really well . Next week
    I bought an upgrade of  networking autocad licenze on 2013 and now the other shop were I bought it are telling me that it's impossible, that autocad dont leave us to install on VMware the licenze.
    Is it true that autocad can't be installed on virtual machine? If it's like this, the reality is that no one professional office can use virtual machines.
    It's really important for professional office know it.
    Arch.Benedetta Fedi
    Please use plain text.
    TravisNave
    Re: AutoCAD 2011 on VMware
    11-29-2012 03:38 PM in reply to: Fedibene
    This is not a problem.  It will work just fine.  The only real problem is with the virtual NIC changing its MAC address and invalidating your license.  You will want to hardcode the NIC settings for the MAC in the VMWare settings so that it does not change.  Otherwise, you shouldn't have any more problems that a virtual machine would normally yield.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Valued Contributor
    11-30-2012 05:57 AM in reply to: Fedibene
    We have found it works, but is NOT supported by Autodesk.
    I recommend you not tell Autodesk or your reseller that it's running on a VM.
    In the past, the support techs would stop helping solve installion or software issues if they knew.
    This attitude is changing, I think. But I don't feel like testing it.
    New Member
    12-04-2012 12:50 AM in reply to: Fedibene
    Questo è quello che mi ha scritto direttamente Autodesk:
    Gentile Sig.ra Fedi,
    E’ vero che le machine virtuali non sono supportate in quanto non sono state testate. Questo non significa necessariamente che non possano funzionare ma semplicemente che non abbiamo gli elementi necessari per fornire soluzioni.
    L’ambiente Parallels (e VMWare Fusion per Mac OS X)  è un’eccezione, le macchine virtuali che utilizzano Parallels hanno superati i test per alcuni prodotti (non tutti, http://usa.autodesk.com/products/mac-compatible-products). Trattandosi di un’informazione ufficiale gli utenti mac non sono fuori regola. In teoria nemmeno chi riesce ad usare Vmware su Windows non lo è, il solo problema è che se dovesse avere problemi non possiamo garantire di poter aiutare a risolverli.
    Distinti saluti,
    Giancarlo Molo
    Il team del Supporto Autodesk
