Installation & Licensing
AutoCAD 2011 installation error
8 REPLIES 8
Message 1 of 9
sanoop
4942 Views, 8 Replies
I can't install AutoCAD 2011 in my laptop. It shows already installed
Solidworks Certified Professional
AutoCAD 2010 Certified Professional
AutoCAD 2010 Certified Associate
8 REPLIES 8
Message 2 of 9
hashim.mundol
in reply to: sanoop
Please try the uninstaller script
http://usa.autodesk.com/getdoc/id=TS16077500
If this doesnt help, we will need to clean up the registry entry from the installer hive or use a 3rd party clean up utility.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Message 3 of 9
TravisNave
in reply to: sanoop
Installation problems may be resolved using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Autodesk Forums:
Message 4 of 9
sanoop
in reply to: sanoop
I have cheched it, but it shows errot- 2147467259- configure product and also AcadLP.msi cannot be uninstalled unless Acad.msi has been uninstalled.
Sanoop
Message 5 of 9
sanoop
in reply to: TravisNave
Thank you for your greate support.
Regards
Sanoop Ezhokaran
Message 6 of 9
svelez
in reply to: sanoop
I CAN'T INSTALL AUTOCAD INTO MY LAPTOP. HOW COULD I DO IT I HAVE WINDOWS 7
Message 7 of 9
DarrenP
in reply to: svelez
is there an error message?
DarrenP
Message 8 of 9
takketan6
in reply to: sanoop
Delete all temporary Files from laptop. Then Run CCleaner or any other software which can fixed your registry error. turn off your PC & then try to install cad. If this is not work then go to this link http://support.microsoft.com/mats/Program_Install_and_Uninstall & run the program installer & Uniinstaller troubleshooter. It will scan errors in your computer & Fixed it automatically or you can try it manually from the option. for any query mail me Takketan6@gmail.com
Message 9 of 9
TravisNave
in reply to: takketan6
@takketan6 wrote:
Delete all temporary Files from laptop. Then Run CCleaner or any other software which can fixed your registry error. turn off your PC & then try to install cad. If this is not work then go to this link http://support.microsoft.com/mats/Program_Install_and_Uninstall & run the program installer & Uniinstaller troubleshooter. It will scan errors in your computer & Fixed it automatically or you can try it manually from the option. for any query mail me.
Is there a reason you responded to a solved post that is more than 2 years old here in this forum?  We appreciate all sorts of help here, but please try to help users with current issues if you wish to participate and add value to the forum.  Thanks!  Smiley Happy
Autodesk Forums:
Administrator Productivity
