Installation & Licensing
Active Member
CADCIV
Message 1 of 7 (638 Views)
AutoCAD 2011 and 2012 (Student Version) Installtion Problems--Urgent fix needed!
638 Views, 6 Replies
09-20-2011 01:15 PM
I have tried to install AutoCAD 2011 and 2012 both but am unable to install either of them.
For AutoCAD 2012, as soon as I start the install, I get an error message. The error goes along the lines of:
"/SecondRun/ lang en-us / FirstRunThreadID 3996"
**Each time I install, the FirstRunThreadID gives a different 4 digit number.
As for AutoCAD 2011, it fails installation at installing Micorosoft Visual C++ 2008 (x86) and installation aborts. (It also USED to fail at installing C++ 2005 but now apparently it passes that and reaches C++ 2008 where it fails)
From Log file for AutoCAD 2011:
InstallMicrosoft Visual C++ 2008 Redistributable (x86)FailedInstallation aborted, Result=193
I am trying to install 64 bit versions of both of them, but both dont work. I'm running a 64 bit WIndows 7 Professional with 4GB RAM.
**I have also manually installed the Visual C++ 2005 and 2008 (x86) and (x64) manually as well as used windows clean up utility to clean up AutoCAD after a failed install.
Any help will be greatly appreciated as I need this program quite urgently.
Product Support
david.lau
Message 2 of 7 (614 Views)
Re: AutoCAD 2011 and 2012 (Student Version) Installtion Problems--Urgent fix nee
09-21-2011 10:26 AM in reply to: CADCIV
Can you check out this post?
http://upandready.typepad.com/up_and_ready/2011/09/autodesk-suites-product-design-suite-will-not-ins...
I am wondering if an updated Microsoft Visual C++ 2010 Redistributable Package is causing the problem.
David Lau
Active Member
CADCIV
Message 3 of 7 (605 Views)
09-21-2011 04:59 PM in reply to: david.lau
I checked the "uninstall a program" and it says I have visual C++ 2005 and 2008 installed but not 2010.
Product Support
david.lau
Message 4 of 7 (586 Views)
09-22-2011 12:44 PM in reply to: CADCIV
Uninstall all the Visual C++ 2005 and 2008 and see if you can install AutoCAD 2011/2012.
David Lau
Active Member
CADCIV
Message 5 of 7 (579 Views)
09-22-2011 01:06 PM in reply to: david.lau
Hi, thanks for the suggestion but I encountered a problem
I was able to unstill the visual c++ 2005 completely but not 2008 (x86). It gives me an error saying "Another program is being installed. Please wait until that installation is complete, and then try installing this software again "  I even reboots my computer but it still gives me this message.
In addition, AutoCAD also fails to instal and crashes at installing the visual 2008 x86.  I think maybe the visual 2008 x86 is corrupted? Any ideas on how to fix it?
Active Member
CADCIV
Message 6 of 7 (565 Views)
09-22-2011 09:41 PM in reply to: CADCIV
Solved the problem. My mistake was unrar-ing the setup files. turns out I didnt have to. It installed!
Thanks for all the effort, appreciated.
Active Member
CADCIV
Message 7 of 7 (563 Views)
09-22-2011 09:48 PM in reply to: CADCIV
ACTUALLY IT DIDNT INSTALL. IT SAYS ONE INSTANCE OF INSTALL IS ALREADY RUNNING AND FAILS AT VISUAL X86
i'll probably reinstall windows
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
