Well that worked! Creating and .msi network image file gives you the
option to designate the server name. As soon as this .msi was installed
on the Client it found the server, and will not start if not connected
to the network as expected.
Am I crazy or did there used to be another option where you could
install AutoCAD Network with out creating a .msi??? I'm thinking like
back to AutoCAD 2005?
john.collyer
> Yes this is a network license, we have registered the license for the
> server FlexLM. That is up and running.
> The documentation provided states and in previous versions of AutoCAD
> allowed you to use a Client utility to authorize the client software,
> installed directly from the CD/DVD, with a network serial number, and
> point it at the FlexLM server.
> Your email showed up just about the time we considered creating the
> .msi which does allow you to enter the server name. I am assuming
> this is all the *pointer* information I need to get the client install
> to lookup the server and FlexLM service to check out a network license???
> So now you have to use a network deployment image, not a client's "
> Network License Activation Utility"?
> Sam Hochberg wrote:
>> You can call 1-800-551-1490, have your s/n, server name and MAC (ethernet)
>> address handy (these are easliy obtained within the LMTools utility).
>> There's also https://register.autodesk.com/
>> You keep mentioning the "client" - these utilities and license files all
>> belong on the server. Once you get the license file all the clients you
>> installed to from the network deployment will look to that server by default
>> for licensing. This *is* a network license we're talking about, right?
