Installation & Licensing
AutoCAD 2010 " Network License Activation Utility" MISSING???
4 REPLIES 4
2392 Views, 4 Replies
How do I get a client AutoCAD install licinced. We have the FlexLM
installed but the "Network License Activation Utility" for the client
is missing from the install disc.
The two following links identified my issue but I still cannot find the
method for authorizing the client installation.
http://forums.augi.com/showthread.php?t=98850
https://registeronce.autodesk.com/custreg/beginRegistration.action
Where do I get a number or create a file for the client installations???
4 REPLIES 4
You can call 1-800-551-1490, have your s/n, server name and MAC (ethernet)
address handy (these are easliy obtained within the LMTools utility).
There's also https://register.autodesk.com/
You keep mentioning the "client" - these utilities and license files all
belong on the server. Once you get the license file all the clients you
installed to from the network deployment will look to that server by default
for licensing. This *is* a network license we're talking about, right?
Sam Hochberg
Inventor Certified Expert
Not too bad at AutoCAD either
"john.collyer >" <"john.collyer" <"john.collyer[a-t]comcast.net"> wrote in
message news:6163745@discussion.autodesk.com...
Yes this is a network
license, we have registered the license for the server FlexLM.  That is
up and running.
The documentation provided states and in previous versions of AutoCAD
allowed you to use a Client utility to authorize the client software,
installed directly from the CD/DVD, with a network serial number, and
point it at the FlexLM server.
Your email showed up just about the time we considered creating the
.msi which does allow you to enter the server name.  I am assuming this
is all the *pointer* information I need to get the client install to
lookup the server and FlexLM service to check out a network license???
So now you have to use a network deployment image, not a client's "
Network License Activation Utility"?
Well that worked! Creating and .msi network image file gives you the
option to designate the server name. As soon as this .msi was installed
on the Client it found the server, and will not start if not connected
to the network as expected.
Am I crazy or did there used to be another option where you could
install AutoCAD Network with out creating a .msi??? I'm thinking like
back to AutoCAD 2005?
john.collyer
> Yes this is a network license, we have registered the license for the
> server FlexLM. That is up and running.
> this is all the *pointer* information I need to get the client install
> to lookup the server and FlexLM service to check out a network license???
To install as a network version you simply need to configure either the deployment image as such or the original install as such. In the Configuration screen of the setup, it is your very first choice. THen you specify your server setup type and the name of your server.
dc
Administrator Productivity
