Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
AutoCAD 2010 - "borrow license" dialog box
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I want to disable "borrow license" dialog box. I think the yellow balloon notification is enough (and good) and users doesn't want to click that dialog box everytime when they launch autocad.
I do not want to use any 3rd party .exe programs to close that dialog box.
Please help!
br,
Jarno
Re: AutoCAD 2010 - "borrow license" dialog box
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you want disable borrow, you can do it on the licence server by using an
option file.
You can't disabled the possibility to access the dialog box in AutoCAD.
Franck Hervet
IT manager
AriCad - France
www.aricad.fr
"JarnoKoppala5328" a écrit dans le message de groupe de discussion :
6300909@discussion.autodesk.com...
> Hi,
> Please help!
> br,
> Jarno
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Franck,
What is the command to disable the borrowing action?
This is a part of my option file:
HOST_GROUP GROUP_S1 PCNAME1 PCNAME2 PCNAME3 PCNAME4 PCNAME5 ... PCNAMEx
INCLUDE_BORROW 72500MAP_2010_0F HOST_GROUP GROUP_S1
RESERVE 9 72500MAP_2010_0F HOST_GROUP GROUP_S1
RESERVE 2 73700CIV3D_2010_0F HOST_GROUP GROUP_S1
I want to give the group S1 the possibility to borrowing a licence, but I want all other users not able to borrow the licence
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Disable borrowing is made with only include_borrow like you do.
But you have to do it for all feature.
In your case you ask to disable for user and you have used HOST_GROUP.
Is there only 1 user by pc ?
If yes you are good.
S'il vous plaît Marquer cette réponse comme "Accepter comme solution" si elle répond à votre question.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This is what I have added on top in my OPT file
HOST_GROUP GROUP_TR INTERNET 192.168.*.*
EXCLUDE_BORROW 72500MAP_2010_0F HOST_GROUP GROUP_TR
EXCLUDE_BORROW 73700CIV3D_2010_0F HOST_GROUP GROUP_TR
The problem is that only the users of S1 may borrow the licence, all other users of the network are not allowed to borrow the license.
Still the EXCLUDE_BORROW seems not to work, not on a HOST_GROUP, nor on HOST_NAME.
It's 1 user per PC
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You will need to use the GROUP keyword to define groups for INCLUDE_BORROW and EXCLUDE_BORROW as the HOST_GROUP does not apply to INCLUDE_BORROW and EXCLUDE_BORROW option lines. Because EXCLUDE_BORROW supersedes INCLUDE_BORROW you will to define your groups so that the users you want to INCLUDE_BORROW for are not in any groups that are specified for EXCLUDE_BORROW.
Chapter 13 of the License Administration Guide (by default “C:\Program Files\Autodesk Network License Manager \LicenseAdministration.pdf") has explanations for the keywords used in options files.
You will also find more information on this topic in this Technical Solution.
Douglas Lauritsen, Autodesk Product Support
Douglas Lauritsen
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This is the Solution
GROUPCASEINSENSITIVE ON
# Alle PC’s met een wilkeurige PCnaam (Dit werkt beter dan de Internet IP adressen) (Wildcards werken ook op namen)
# Wildcards alos work for PC Names and seems better to work then the IP addresses
HOST_GROUP XTR *
EXCLUDE_BORROW 72500MAP_2010_0F HOST_GROUP XTR
# De PC’s die enkel toegang hebben
HOST_GROUP TROKE VISTA-LJMP
INCLUDE_BORROW 72500MAP_2010_0F HOST_GROUP TROKE
Extra punt die we niet over het hoofd mogen zien Als de licentie file in een andere folder staat dan de ADSKFLEX.EXE dan moet de ADSKFLEX.OPT niet in de folder van de exe staan, maar wel in de folder van de licentie file.
Extra Point to be mentioned: In case the LIC file is in another file then de adskflex.exe file, the option file must be in the same folder as the lic file.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The solution proviced is actually not the answer to the question.
The question is/was how to disable the license borrow notification window when a license is already borrowed.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This cannot be done.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
