• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    AutoCAD 2010 Home Use - 32-Bit and 64-bit installs - Different Serial Numbers?
    951 Views, 1 Replies
    07-11-2011 03:36 PM
    We have a 5 seat network license for AutoCAD 2010.  I have three employee home users, two wants to install 32-bit version of AutoCAD 2010, and one employee user wants to install the 64-bit version.  We requested and received a home use serial number from autodesk, which stated that we could use it for 5 home use installs.  The serial number worked for the 32-bit installs, but will not work for the 64-bit install.  The 64-bit install will only be the third home use license.  Any suggestions on how to remedy this issue.  Is a different serial number required to install the 64-bit version of the same software (autoCAD 2010)?
    Thanks Much......
    Please use plain text.
    Product Support
    Re: AutoCAD 2010 Home Use - 32-Bit and 64-bit installs - Different Serial Number
    07-12-2011 04:35 AM in reply to: rlayaoen
    Usually serial numbers are not specific to 32 bit or 64 bit.
    If you are installing Autocad 2010, serial number should, Do you get invalid serial number error ?
    did you have any other version of Autocad installed on this machine earlier ?
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    For more tips & tricks: http://upandready.typepad.com
    Hashim Mundol
    Autodesk Product Support
    Autodesk, Inc.
