Installation & Licensing
AutoCAD 2006 - English installation is aborted
5 REPLIES 5
4165 Views, 5 Replies
Hi
When i install AutoCAD 2006 the .net frame stated installing and after that the error message came saying that AutoCAD 2006 - English installation is aborted. Please check "C:\Document~1\ADLM~1.IMC\LOCALS~1\Temp\AutoCAD 2006 Setup.log" for details.
This message comes in 2 PC where Mechanical Desktop 2005 installed. Please any one help me in this regards
5 REPLIES 5
TravisNave
You might need to use the .NET Framework Clean-up tool to remove your Framework. Then install AutoCAD. I'd also recommend putting on .NET 3.5 SP1 afterwards.
You can download the tool from Microsoft or try searching for my post about it in this forum. Good luck!
Autodesk Forums:
Hi
thnaks fro reply but i need your help
AutoCAD English Problem not solve after .NET fram work remove tool. i insstall this tool abd clean .NET framework complete files and then i install AutoCAD 2006 but same problem "ENglish Installation is aborted" so What can i do. Please solve my Problem,
Regards AD Siddiqui
TravisNave
Post the setup log listed in that error path.  Please zip it.
Autodesk Forums:
i have same problem in my pc plzzzzzzzzzzzzz help me plzzzzzzz
TravisNave
Welcome to the forum.
You have to include screencaps and log files and a description of your system for us to properly help you.
Autodesk Forums:
Administrator Productivity
