Buds,
I checked with our authorizations department. There are no current plans to
discontinue issuing authorization codes for AutoCAD 2000i so you will be
fine with auth codes.
Your exposure to problems has more to do with evolving technology. For
example, if new operating systems or service packs render the AutoCAD 2000i
licensing system unusable you would not be able to get any help on that
issue.
Jerry Milana,
Autodesk Consulting
"buds" wrote in message
news:7040339.1095516189522.JavaMail.jive@jiveforum1.autodesk.com...
> Hi
> I am aware that AutoCAD 2000i will expire on January 15,2005, so It means
all upgrades and technical support will no longer be offered.
> But regarding on the technical support, I would like to ask if the
authorization of code is also affected?
> For Example, We have 28 AutoCAD 2000i NLM license installed on our server
and we bought this software only for the last 2 years(2002 and 2003) But
right now due to our budget constraints we can not upgrade immediately our
2000i to 2005. If the server network card fails or malfunction on Jan. 30,
2005. Of course We have to re-install the AutoCAD 2000i NLM on our server
and request for authorization code. Does the Autodesk will give us a new
Authorization Code?
> Because one of the dealer told us that Autodesk will not give any
Authorization Code for 2000i starting Jan 16. 2005 and we have to buy
AutoCAD 2005? Is this true?
