Steve,
While Mark's advice will usually work there is a possibility that a server
code change may occur even if you do not change hardware. Any change to the
network properties of your system may cause a server code change and it may
not be obvious what you did to not get the same code as last time. If the
server code changes you will need to get new authorization code(s). Prior
to starting your rebuild, run AdLM Admin to determin and record your server
code. As soon as you have completed your operating system work reboot at
least twice then run AdLM Admin to check your server code. If it did not
change, you are good to go with your old lic files. So, it is best to plan
this work within a timeframe that will allow you to get new authorization
codes from us. The license management system supplied with AutoCAD 2002
eliminates this uncertainty but of course does not work with 2000i
jerry milana
Autodesk Product Support
"Mark Taylor [Autodesk Support]" wrote in
message news:F5303CF8B60D25F77E2374E988992E17@in.WebX.maYIadrTaRb...
> Steve Rudd wrote:
> > Hi All,
> > Earlier we had a software fault bring our Licence Manager server down
and as
> > a result, the engineering office was unable to function.
> > The server operating system is Windows NT4 with service pack 5.
> > We managed to restart the server with base NT4 and thus permit the use
of
> > AutoCAD.
> > However, we now wish to rebuild the server over the weekend and install
> > service pack 6.
> > Is it possible for us "Back-up" the current AutoCAD licensing files
which
> > exist on the server, and then reinstate them onto the rebuilt server
without
> > having to obtain new authorisation codes?
> > AutoCAD 2000i SP2, W2k Pro SP3
> Hi Steve,
> You should find the license files (three digit number with LIC extension)
located in the Key
> subdirectory from the license manager install. If you back these up,
flatten the server, reinstall
> the OS, reinstall the NLM (ensure it is stopped), replace the LIC files,
then start the NLM, all
> should be fine (assuming you are making no hardware changes).
> Mark Taylor
> Product Support, EMEA
> WW Support & Services, Autodesk
> Discussion Q&A: http://www.autodesk.com/discussion
