• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    *Malard, Fernando Poinho
    AutoCAD 2000 real slow performance
    119 Views, 3 Replies
    02-04-2000 08:20 AM
    Subject: Re: AutoCAD 2000 real slow performance
    Date: sexta-feira, 4 de fevereiro de 2000 15:15
    Chris,
    Your network is base on a Windows NT Server?
    Do you have any AutoCAD 2000 settings files like Plot CTB files been used
    from a network share?
    Is TCP/IP your default network protocol?
    Fernando.
    "Chris Shields" wrote in message
    news:87f0j2$m7917@adesknews2.autodesk.com...
    > I have tried that I have not seen any difference in performance. Any
    other
    > ideas?
    > "Fernando Poinho Malard" wrote in message
    > news:87evk6$m7a32@adesknews2.autodesk.com...
    > > Chris,
    > > I have a Penitium II 300, Asus motherboard, 128 Mb RAM, Windows NT 4.0
    > > Service Pack 6 and all AutoCAD 2000 patches installed. Everything is
    fine
    > > for me!
    > > Did you try to format and install a fresh copy of Windows NT 4.0
    > > and AutoCAD 2000?
    > > Some problems may occur from incorrect installation of other
    application.
    > A
    > > good test is to install the minimal software, in other
    > > words, Windows NT 4.0 (with Service Pack 6) and AutoCAD 2000. After that
    > try
    > > to install one by one application to see if anyone is causing the
    problem.
    > > Fernando.
    > > news:87ev7f$m9530@adesknews2.autodesk.com...
    > > > We are presently using AutoCAD 2000 in a lab environement using a
    > network
    > > > license on DELL Precision 410 workstations with 400 pII, 256 mb RAM,
    > Fire
    > > GL
    > > > Pro 1000 video cards with 8mb RAM, and window NT 4.0. For some reason
    > we
    > > > are getting very slow performance to the point where AutoCAD 2000 will
    > > lock
    > > > up at times. I have applied all the latest patches and updates and
    > > nothing
    > > > has seemed to help does anyone have any ideas, because I'm running
    out.
    > > > Thanks,
    > > > Chris Shields
    Please use plain text.
    *Shields, Chris
    02-04-2000 09:11 AM in reply to: *Malard, Fernando Poinho
    <<< Message <87ev7f$m9530@adesknews2.autodesk.com> was originally posted to 'autodesk.autocad.2000general' on Fri, 4 Feb 2000 10:33:08 -0600.>>>
    We are presently using AutoCAD 2000 in a lab environement using a network
    license on DELL Precision 410 workstations with 400 pII, 256 mb RAM, Fire GL
    Pro 1000 video cards with 8mb RAM, and window NT 4.0. For some reason we
    are getting very slow performance to the point where AutoCAD 2000 will lock
    up at times. I have applied all the latest patches and updates and nothing
    has seemed to help does anyone have any ideas, because I'm running out.
    Chris Shields
    *Shields, Chris
    <<< Message <87f0j2$m7917@adesknews2.autodesk.com> was originally posted to 'autodesk.autocad.2000general' on Fri, 4 Feb 2000 10:56:29 -0600.>>>
    I have tried that I have not seen any difference in performance. Any other
    ideas?
    > Chris,
    > Service Pack 6 and all AutoCAD 2000 patches installed. Everything is fine
    > for me!
    > and AutoCAD 2000?
    > Some problems may occur from incorrect installation of other application.
    A
    try
    > to install one by one application to see if anyone is causing the problem.
    > Fernando.
    network
    Fire
    > GL
    we
    > lock
    > nothing
    > > Thanks,
    > > Chris Shields
    *Shields, Chris
    02-07-2000 06:32 AM in reply to: *Malard, Fernando Poinho
    No and Yes the server where the CAD users access data and files is Windows
    NT, but it is primarily a Novell Network(Netware 5.0) and we are using
    NDS4NT, No, Yes.
    news:87f54k$p5010@adesknews2.autodesk.com...
    > From: "Fernando Poinho Malard"
    > Chris,
    > Fernando.
    > other
    > > ideas?
    > > > Chris,
    > fine
    > > > for me!
    > > > and AutoCAD 2000?
    > application.
    > > A
    that
    > > try
    > problem.
    > > > Fernando.
    > > network
    > > Fire
    > > > GL
    reason
    > > we
    will
    > > > lock
    > > > nothing
    > out.
    > > > > Thanks,
    > > > > Chris Shields
