I know the problem about adesksys.dll but in my situation (acad.exe running
from the server) that file is installed, with the rest of the executables,
on the NT 4 Server (I have no acad.exe and adesksys.dll on the clients) and
in the patch instructions is told to copy it only on the machines running
Windows 2000.
Thank you very much.
"jason martin" ha scritto nel messaggio
news:A0750C9D6B2D78EA309039A1A5B9571B@in.WebX.maYIadrTaRb...
> Pierpaolo -
> Yes, there is a problem running the network version of autocad 2000 on w2k
machines. It
> involves the differences in the way previous versions of win use tcp/ip
and acquire
> licenses from the server.
> There is a file, in the same folder as the acad.exe called adesksys.dll.
The file that
> ships with autocad 2000 will not work with w2k. You can get a new version
of the
> adesksys.dll file at
ftp://adeskftp.autodesk.com/prodsupp/autocad2000/patches/adesksys.dll
> (watch for wrapping in the url). You will need to replace the adesksys.dll
file that is
> installed with the new one downloaded from the link above.
> Also - If you plan to run with standard user rights on w2k there are some
issues that you
> need to know about. Plain user rights are not adequate to run autocad 2000
correctly. You
> need to have at least power user rights or refer to the tech doc located
> http://support.autodesk.com/knowledgebase/html/336082.htm (watch for
wrapping again).
> That is all that I can think of right now. Let us know if you have
problems.
> hth
> jason martin
> frankfurt-short-bruza
> "ITALIA Software S.a.s. - Pierpaolo Cravero"
wrote in message
> news:5AD8B3BA4DBA9ED297CEAE6FF3DBA32B@in.WebX.maYIadrTaRb...
> > I have installed AutoCAD 2000 program files and the license manager on a
Win
> > NT 4 server and I' m planning to install Win 2000 pro on the clients
> > launching AutoCAD from the server (network deployement ?): someone know
if
> > there are known problems?
> > Pierpaolo.
