Installation & Licensing
AutoCAD 14 will not install
5 REPLIES 5
optiwolfe
1118 Views, 5 Replies
AutoCAD 2014 will start the installation. Here is the result from the setup log
2013/9/7:16:30:27 rwolfe RWOLF071304 === Setup started on RWOLF071304 by rwolfe === 2013/9/7:16:30:27 rwolfe RWOLF071304 Path_Length: 155 2013/9/7:16:30:27 rwolfe RWOLF071304 Current Directory 😧 2013/9/7:16:30:27 rwolfe RWOLF071304 Launch 2013/9/7:16:30:27 rwolfe RWOLF071304 CommandLine    2013/9/7:16:30:27 rwolfe RWOLF071304 Path_Length: 155 2013/9/7:16:30:27 rwolfe RWOLF071304 Current Directory C:\Users\rwolfe\AppData\Local\Temp\_AI7BF5.tmp 2013/9/7:16:33:59 rwolfe RWOLF071304 === Setup ended ===
2013/9/7:16:30:30 rwolfe RWOLF071304 === Setup started on RWOLF071304 by rwolfe === 2013/9/7:16:30:30 rwolfe RWOLF071304 Path_Length: 155 2013/9/7:16:30:30 rwolfe RWOLF071304 Current Directory C:\Users\rwolfe\AppData\Local\Temp\_AI7BF5.tmp 2013/9/7:16:30:30 rwolfe RWOLF071304 Launch 2013/9/7:16:30:31 rwolfe RWOLF071304 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\rwolfe\AppData\Local\Temp\_AI7BF5.tmp\Setup\AcSetup.dll 2013/9/7:16:30:31 rwolfe RWOLF071304 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2013/9/7:16:34:01 rwolfe RWOLF071304 === Setup ended ===
Went through all the preparation steps, but can't get an installation. Any  suggestions?
5 REPLIES 5
m_latz
in reply to: optiwolfe
Have you tried to call setup.exe in compatibility mode:
dembkod
optiwolfe,
Hello. Clear out your TEMP files and turn off your Antivirus. Then open your Task manager and make sure your Antivirus is not running.
Then uninstall ALL the Microsoft C++ entries. Most machines have multiples. I would uninstall all C++ and then uninstall the NET on the system and then try to install the program. It should install the C++ versions it is in need of.
Thank you for taking part in our community!
David Dembkoski
optiwolfe
in reply to: dembkod
Spoiler
Trend Micro needed to be disabled to allow the install. Thanks for the tip.
rezoloot
I had the ssme issue, tried all the turn offs including FW, AV, I ended up downloading the stand alone .net 4.5, installed that, then took ownership of the folders it created during instal, it repeatedly told me I didnt have rights to create a folder inside my own user folder, which is madder than cheese because Im the only user and admin.
Not sure if this helps any more than was said but it was no mean feat believe me to install this, however, it did instal everything including lisp and SP1 in one foul swoop
Hope it helps
rmoore2013
in reply to: rezoloot
Have AutoDesk fix the issue with AutoCAD 2014 installs on a Windows 7 system with .net 4.5
Administrator Productivity
