I've tried downloading 3ds max several times and I keep getting the same message during installation, the files are corrupt and I need to download again. I've tried turning off all virus,spyware and firewall protection and anything else running in the back that might interfere with the download. Nothing works. Also the download has gotten progressively faster. At first it took eight hours. Now it only takes a few minutes before it says the download is complete. Is there anything I can do to fix this?
Solved by david.lau. Go to Solution.
Redownload it using Firefox and use a Browser Download instead of the Download Manager.
The Download Manager drops the files here:
http://forums.autodesk.com/t5/Installation-Licensing/Akamai-Cache/m-p/2878186#M28118
Hi ilani.marquez
I would try from another machine if possible. I've noticed that doing more than 1 download at a time can cause issues, even from within the Autodesk network so I would try only 1 at a time. But it sounds like you have tried several times so if you have subscription I would simply request a DVD installer
dwayne
