• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *McNeely, Jack
    Authorize AdLM?
    76 Views, 3 Replies
    09-11-2000 10:51 AM
    Do I need an authorization code for the AdLM itself? If so, what serial
    number do I use? Will I need to re-authorize if I have an older version
    running on the same server that will be upgraded?
    Please use plain text.
    *Nehls, Kevin
    Re: Authorize AdLM?
    09-11-2000 11:19 AM in reply to: *McNeely, Jack
    No, you don't need to authorize the AdLM itself. You do need the server
    code that is generated, you get this through the AdLM Admin tool, and your
    autocad serial number(s) to get authorization codes for your autocad
    licenses. Once you get the authorization codes for you autocad licenses
    then you just enter those in the AdLM Admin tool. You will only ever need
    to re-authorize the codes for you licenses if the server code changes. The
    server code can change if you change certain pieces of hardware, like a NIC,
    or if you change the IP address, as well as various other things.
    If you ever plan on performing any work or upgrades on the AdLM server, just
    write down what the current server code is as well as any changes that you
    make to the server. Once you are done making your changes check to see if
    the server code changed. If it didn't you are in the free and clear, if it
    did then you have to re-authorize your licenses.
    Kevin Nehls
    remove -ns- for direct reply
    "Jack McNeely" wrote in message
    news:6DF50AF9E22CE486B5AB5AC31D946D78@in.WebX.SaUCah8kaAW...
    *Montejo, Richard D.
    Re:
    09-11-2000 09:14 PM in reply to: *McNeely, Jack
    Hi Kevin,
    I'm trying to deploy my files to my client yet they
    can't access the folder where I placed the setup file
    for client deployment, but they can access my other
    folders. Should I authorize my AdLM first before
    they can install the deployment or not necessarily?
    Richard D. Montejo
    *martin, jason
    Re:
    09-12-2000 05:38 AM in reply to: *McNeely, Jack
    No it is not necessary to authorize the adlm before the install can take
    place. Check the rights to the folder where the netsetup is. You can
    install to all of the clients that you want without the adlm functioning.
    It makes no difference until you try to actually run autocad.
    hth
    jason martin
    frankfurt-short-bruza
    Richard D. Montejo wrote in message
    news:AB15577B8348D05412D1AB73A80655F8@in.WebX.SaUCah8kaAW...
    > Hi Kevin,
    > Richard D. Montejo
