• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Valued Contributor
    Re: Authorization window is blank
    08-09-2011 08:02 AM in reply to: praveens_02
    After reading all these posts I came to the conclusion that staying with ACA2010 was the right decision. Now I don't lose my precious time configuring my workspace at each new release.
    Upgrades should occur in a 3 year cycle and include new tools (not a new interface at each new version).
    Pedro Aroso
    http://ferramentasdearquitecto.blogspot.com/
    Please use plain text.
    New Member
    irankzz
    01-24-2012 11:30 AM in reply to: asherwa
    Where's the solution to this problem? I went into registry and 1400 value was already 0.
    *Expert Elite*
    TravisNave
    01-24-2012 01:02 PM in reply to: irankzz
    For more information on this known Autodesk Support Knowledge Base article, please follow this link:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
    Additional discussion about this issue can be found here:
    http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
    New Member
    irankzz
    01-25-2012 10:38 AM in reply to: pedroaroso
    Well I got it to work, so thanks everyone. I had to restart internet explorer. I also had to delete the L folder before the zero folder in the registry that was mentioned earlier. The fix works, just remember to do the small housekeeping stuff afterward.
    extra kudos to "karan9delhi"
    Ira
    New Member
    janiramirez30
    01-30-2012 07:37 PM in reply to: asherwa
    i downloaded Maya 2012 but when i try to activate it, it gives me a blank window.
    how do i fix it? (:
    New Member
    janiramirez30
    01-30-2012 07:40 PM in reply to: asherwa
    ok so like, i did what the instruction said to fix the blank window but it doesn't seem to work
    Customer Service
    arlinpega.bibat
    01-30-2012 08:24 PM in reply to: janiramirez30
    Hi janiramirez30:
    You may follow the steps provided through this link:http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
    "The first solution is to go into Internet explorer>Tools>internet options or control panel > internet options.
    Under the security tab, choose internet zone. Click custom level, and enable the options pertaining to ActiveX ontrols ans java scripting".
    Let us know if this worked for you. You may also send us the serial number through  privatem message (envelope next to your account name at the top of this page) so we may have a look further.
    Thank you for your cooperation.
    Arlin Bibat
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    New Member
    nayandeepak551
    02-02-2012 02:20 PM in reply to: asherwa
    HI. I have downloaded my student version. During the installation i have entered the serial yet during first run autocad prompts me to activate. But on clicking activate, only a black screen comes.
    philip.s
    02-02-2012 02:33 PM in reply to: nayandeepak551
    nayandeepak551,
    Did you follow the steps outlined in the link contained in the above post?
    Philip Schmelzer
    TW | PI | YT | BLOG
    New Member
    nayandeepak551
    02-02-2012 02:57 PM in reply to: philip.s
    yes i have tuned the registry yet i am unable to activate it.
