Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Authorizat ion window is blank
- Highlight
- Email to a Friend
I have got the same problem -Register today form is blank and shows only two radio buttons- I m useing 3dmax 9 on windows 7 home premium.
and i used these settings. but it is not working.
"Solution:
http://usa.autodesk.com/adsk/servlet/ps/item?siteI
This issue can occur if Active Scripting is disabled for the My Computer zone.
To enable Active Scripting
On the Windows (Start) menu, click Run.
In the Open dialog box, enter REGEDIT and click OK
In the Registry Editor, find the following subkey:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre
Double-click the 1400 value.
In the Edit String dialog box, under the Value data field, enter 0.
Find the following subkey:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr
In the Edit String dialog box, under the Value data field, enter 0."
i have attached the Register today blank form pic
Please someone help.
Re: Authorizat ion window is blank
- Highlight
- Email to a Friend
Other users have had success launching the product as Administrator and activating that way.
For more information on this known Autodesk Support Knowledge Base article, please follow this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Authorizat ion window is blank
- Highlight
- Email to a Friend
hey guys i have found the solution...
http://forums.autodesk.com/t5/forums/replypage/boa
i have deleted the invalid one other than ; 1,2,3 and 4
Having a My Computer security zone is somewhat unusual. Typically, there are only four security zones: Internet, Local intranet, Trusted sites, and Restricted. In this case, examining the registry may also find a subkey under Zones named with a "broken" character at:
- Highlight
- Email to a Friend
Thank you so much... now max is working properly again thank u.
- Highlight
- Email to a Friend
same problem, been busy for hours allready trying to fix this, please HEEELLP!!
I tried all these sulutions:
http://area.autodesk.com/forum/autodesk-3ds-max/in
have IE 9 as default (javascript enabled)
a new 64bit Dell with windows 7
nothing works...
- Highlight
- Email to a Friend
OK fine..do not do any thing
just follow this... even i have dell.
go to run type regedit
locate HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre
now you will see there is something with the letter "L" just above O.
. Delete only "L"
.. http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
send me the snapshot if you face error.
- Highlight
- Email to a Friend
I didn't want to start a new thread for this... I'm hoping this translates. I'm running Windows 7 on a brand spanking new iMac.
I have been running my Revit Architecture 2011 Suite without incident since it was set up 2 weeks ago. That is until yesterday. The product searches for the license server on booting up, then tells me I need to activate the product.
Ok, no problem...
Connecting to Autodesk for a new key and to activate the product causes Windows 7 to flag me with a 'program not responding' and then locks me out of it. The same thing happens when I try to enter the Activation Code that Autodesk gave me last night. No Go.
BTW - the acticvation windows show up just fine for Revit and AutoCAD- it'll let me get that far without issue... its the 'next' button to authorize the product that causes the immediate "Program Not Responding" interruption, and locks me out of Activation as well as Revit. It won't even Run in Demo mode.
Now, I've done the suggested registry editing (which was already set to Zero), I've done tried to run it as an Admin and license it that way, I've even shut off all the security protocols, and then run the software as an admin..
NONE of the things that I've tried here will make Windows 7 cooperate and let Either Revit 2011 or AutoCAD 2011 talk to the server and get this thing authorized.
I've called the local Autodesk Rep, I've called our tech support, and I've been researching this problem and possible solutions all night.
I've caught a brief flash of a script error on one of these attempts... which hasn't appeared before or since. Which is what led me to believe that the registry was indeed the problem. I have no broken registry entries, and everything seems to be where it's supposed to be - according to all the information that I've been able to find.
So my question is - sure this might work for some people - but do you have any other fixes?
I'm coming up on 2 days lost work because of this, and I can't afford to see day 3 without a solution.
JM
- Highlight
- Email to a Friend
what is that?
- Highlight
- Email to a Friend
thank you man ![]()
- Highlight
- Email to a Friend
I have got the same problem -Register today form is blank and shows only two radio buttons- I m useing 3dmax 9 on windows 7 Ultimate. I also tried below settings for through the regedit.
Please help me anyone..
