Installation & Licensing
Authorization # location
3 REPLIES 3
225 Views, 3 Replies
Hey all:
Can I find my authorization number on my computer? I'm getting new computer and would like to install product again. Thanks.
3 REPLIES 3
TravisNave
You must get that number from Autodesk or thru your reseller.
If it will not authorize over the internet, you will need to give your request code manually so you can receive your authorization code. The codes are different per machine and are not tranferrable.
Good luck.
Autodesk Forums:
Thanks!
You'll get the trial period automatically on your new PC, by the way
(usually 30 days). You can find the name, address, and other info you
entered before by searching Documents and Settings for the file "RegInfo".
As Travis says, you'll need a new auth code; they can't be reused.
--Cy--
wrote in message news:5033240@discussion.autodesk.com...
Hey all:
Administrator Productivity
