Installation & Licensing
Active Member
rl88
Message 1 of 3 (239 Views)
At Wits End w/ ACAD Civil3D Install
239 Views, 2 Replies
01-18-2012 06:47 PM
Help!
I had ACAD 2012 and ACAD Map3D 2012 on my machine.  I went for Civil 3D 2012, but it won't install.  See attached log.
I uninstalled all existing ACAD per instructions on this forum, cleaned out my registry, deleted all kinds of ACAD folders per the instructions, tried a "clean install" -- still hangs.
I get the red X message that says 1: 5 2: adlmPITSetProductInformation failed. 3: 2
Then at the end, I'm told the installation failed.  This is so maddening!!
My box:
Dell Optiplex 390
Windows 7 Enterprise, SP 1
64-bit
8.0 GB RAM
TravisNave
Message 2 of 3 (234 Views)
Re: At Wits End w/ ACAD Civil3D Install
01-19-2012 07:44 AM in reply to: rl88
The PIT file error is a known issue.  You can find more about it in the following Autodesk KB:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13540825&linkID=9241177
Your installation log also shows failure on installing Microsoft Visual C++ 2005 Redistributable (x86).  If you have any existing version already on your computer, uninstall it from Control Panel, reboot, and try the installation again.  You can also attempt to install this prerequiste manually from Microsoft.
http://www.microsoft.com/download/en/details.aspx?id=3387
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Active Member
rl88
Message 3 of 3 (228 Views)
01-19-2012 08:30 AM in reply to: TravisNave
Got it!  Thank you!!!!!  :smileyvery-happy:
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
