HI!
I would like to seek help regarding an error when running Revit MEP 2012 which is part of the Building Design Suite Ultimate 2012. All the other softwares that are part of the said suite are running okay, however, when we run Revit MEP after successful installation of the suite the following error occurs:
"Revit could not load C:\Program Files\Autodesk\Revit MEP 2012\Program\Arrayelemsdb.dll"
All the machines installed with BDS Ultimate have the same error. The machines are new and meets the system requirements for BDS.The funny thing is, we have also installed BDS Premium on the other new machines with the same specs and all softwares including Revit MEP runs correctly.
If anyone can suggest or help, please do. Thanks in advance!
