• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    Architecture 2013 Install Error 1603
    1474 Views, 2 Replies
    10-18-2012 10:13 AM
    We are receiving the dreaded error 1603 when trying to install Arch 2013. The ACA 2013 Setup Log is below. I've read a number of discussion posts on fixing it, but they all seem to point the 1603 error referencing DOTNET, DirectX or C++. This error just points to Arch 213 causing the failure. Any help on finding the problem would be appreciated!
    EDIT: I've attached both log files in a zip, in case that helps.
    -Eric
    2012/10/18:12:01:28 archiDave ARCHIDAVE-PC === Setup started on ARCHIDAVE-PC by archiDave ===
    2012/10/18:12:01:28 archiDave ARCHIDAVE-PC Launch
    2012/10/18:12:01:33 archiDave ARCHIDAVE-PC PageOpen LaunchDialog
    2012/10/18:12:01:38 archiDave ARCHIDAVE-PC PageOpen LicenseDialog
    2012/10/18:12:01:42 archiDave ARCHIDAVE-PC PageOpen ProductInfoDialog
    2012/10/18:12:01:58 archiDave ARCHIDAVE-PC PageOpen ProductSelectionDialog2
    2012/10/18:12:02:24 archiDave ARCHIDAVE-PC PageOpen FullProgressDialog
    2012/10/18:12:02:24 archiDave ARCHIDAVE-PC Installing AutoCAD® Architecture 2013: TRANSFORMS="C:\acad_arch_2013\x64\en-us\ACA\ACA.mst;C:\Users\ARCHID~1\AppData\Local\Temp\_AI1E2E.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\acad_arch_2013\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2012/10/18:12:04:23 archiDave ARCHIDAVE-PC Install AutoCAD® Architecture 2013 Failed Installation aborted, Result=1603
    Please use plain text.
    Product Support
    byron.morales
    Re: Architecture 2013 Install Error 1603
    10-19-2012 11:34 AM in reply to: elor
    Hello:
    In regards to AutoCAD Architecture not installing onto your computer, please Uninstall, re-install of the
    VCREDIST (Microsoft Visual C++) packages. Usually, it works best to uninstall them in this order
    2010 x86
    2008x64
    2008x86
    2005x64
    2005x86
    Then reinstall in the opposite order:
    2005 x86
    2005 x64 etc.
    You can locate the packages in the 3rdParty\x86 and 3rdParty/x64 VCREDIST folders in the install media or
    deployment.
    Then Run the dotNetFx40_Full_x86_x64.exe file located on the \3rdParty\NET\4\wcu\dotNetFramework folder and select Repair.
    Reboot computer, Turn Antivirus Off, Clear the contents of the %temp% folder and then attempt to re-install the software.
    If the installation fails please Create a new local user account on the computer and give it administrator rights and log into computer with this newly created test account. Turn UAC Off and Turn Antivirus software Off then attempt to install the software.
    If the installation fails under this test account as well please reply back and include any  screen captures of error messages and also include the setup and install log files found on the %temp% folder.
    Byron Morales
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution:smileywink:
    Byron Morales
    AutodeskCare | Support Specialist
    TW | PI | YT | BLOG
    Distinguished Contributor
    dgizzim0
    10-23-2012 03:07 PM in reply to: byron.morales
    Pretty sad that in order to install this, other installations have to be uninstalled and reinstalled. This seems to be an Autocad issue trying to pass the buck.
