• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Patnaude, David
    Arch Desk using Acad14 license
    218 Views, 5 Replies
    10-20-1999 05:35 AM
    I had 22 Acad 14 licenses installed on a Novell NetWare 5 network and now
    have upgraded 1 license to Architectural desktop. I obtained new server
    codes and I am no showing 1 141 license for Arch Desk and still have 22
    licenses shown for 140 - Acad14. However, the Arch Desktop installation is
    aquiring and Acad14 license instead of the Arch Desk license. This
    somewhat defeats the purpose of the 1 arch desk network license if anyone
    that can access Acad14 can run Arch Desk.
    Any ideas why the wrong license type is being picked up?
    David Patnaude
    dpatnaude@tamsconsultants.com
    Please use plain text.
    *Milana, Jerry
    Re: Arch Desk using Acad14 license
    10-20-1999 10:41 AM in reply to: *Patnaude, David
    David,
    ADT requires two "tokens" a 140 for the base AutoCAD feature and a 141 for ADT
    specific functionality. The 141 token will not be pulled until an ADT specific
    command is used.
    When you received your authorization codes, you should have gotten two, one
    should create the 141.lic file and the other should update the 140.lic with a
    license count equal to your AutoCAD plus ADT counts. Note that AdLM Admin must
    be run for each authorization code you receive and that on Novell, you must
    stop the AdLM prior to updating the files.
    Jerry Milana,
    Autodesk Product Support
    > David Patnaude
    *Patnaude, David
    Re:
    10-20-1999 12:57 PM in reply to: *Patnaude, David
    milanaj@autodesk.com (Jerry Milana) wrote in
    <380DFECF.85380DA@autodesk.com>:
    >David,
    >for ADT specific functionality. The 141 token will not be pulled until
    >an ADT specific command is used.
    >one should create the 141.lic file and the other should update the
    >140.lic with a license count equal to your AutoCAD plus ADT counts.
    >Note that AdLM Admin must be run for each authorization code you receive
    >and that on Novell, you must stop the AdLM prior to updating the files.
    >Jerry Milana,
    >> now have upgraded 1 license to Architectural desktop. I obtained new
    >> server codes and I am no showing 1 141 license for Arch Desk and still
    >> have 22 licenses shown for 140 - Acad14. However, the Arch Desktop
    >> installation is aquiring and Acad14 license instead of the Arch Desk
    >> license. This somewhat defeats the purpose of the 1 arch desk network
    >> license if anyone that can access Acad14 can run Arch Desk.
    >> David Patnaude
    This is the procedure that I followed and ADLM Query is showing 22 140
    licenses and 1 141 license on the server, but when starting ADT, the 1 141
    license is still available and 1 140 license has been taken instead.
    David Patnaude
    *Milana, Jerry
    Re:
    10-20-1999 02:06 PM in reply to: *Patnaude, David
    David,
    ADT will ALWAYS use a 140 token. It will also use a 141 only when an ADT
    specific command is used. If in fact you own 22 AutoCADs and 1 ADT then your
    140 seat count should be 23. Stop AdLM and reenter your auth codes again and
    see what AdLM Admin says you have.
    jerry
    > >David,
    > >Jerry Milana,
    > >> David Patnaude
    > David Patnaude
    *Patnaude, David
    Re:
    10-21-1999 05:24 AM in reply to: *Patnaude, David
    <380E2EC0.7764D03@autodesk.com>:
    >David,
    >ADT specific command is used. If in fact you own 22 AutoCADs and 1 ADT
    >then your 140 seat count should be 23. Stop AdLM and reenter your auth
    >codes again and see what AdLM Admin says you have.
    >jerry
    >> >David,
    >> >141 for ADT specific functionality. The 141 token will not be pulled
    >> >until an ADT specific command is used.
    >> >two, one should create the 141.lic file and the other should update
    >> >the 140.lic with a license count equal to your AutoCAD plus ADT
    >> >counts. Note that AdLM Admin must be run for each authorization code
    >> >you receive and that on Novell, you must stop the AdLM prior to
    >> >updating the files.
    >> >Jerry Milana,
    >> >> and now have upgraded 1 license to Architectural desktop. I
    >> >> obtained new server codes and I am no showing 1 141 license for
    >> >> Arch Desk and still have 22 licenses shown for 140 - Acad14.
    >> >> However, the Arch Desktop installation is aquiring and Acad14
    >> >> license instead of the Arch Desk license. This somewhat defeats
    >> >> the purpose of the 1 arch desk network license if anyone that can
    >> >> David Patnaude
    >> 141 license is still available and 1 140 license has been taken
    >> instead. --
    >> David Patnaude
    Thanks Jerry. I had not tried to invoke any ADT commands before since I am
    not an Architect and did not realize that it would also use a 140 license.
    The ADT license was an upgrade to one of my Acad14 licenses, so I believe
    that the 22 140 licenses and 1 ADT license is still correct.
    Thanks again for your help.
    David Patnaude
    *Milana, Jerry
    Re:
    10-21-1999 09:00 AM in reply to: *Patnaude, David
    David,
    I'm glad you have a level of comfort with the situation now.
    jerry
    > >David,
    > >jerry
    > >> >David,
    > >> >updating the files.
    > >> >Jerry Milana,
    > >> >> David Patnaude
    > >> instead. --
    > >> David Patnaude
    > David Patnaude
