Yes, it tedious
Yes, we would prefer Autodesk giving us proper software to update the
installation point, it's not that difficult to do. With a couple of hundred
workstations to install, we don't want to first install and then update all
the workstations as we are only now updating from 2000i to 2002.
We have tested this with 2000i and 2002, it works on both, why not the
others.
Juha
"Charles Prettyman" wrote in message
news:8A3C16219ECA8276FEC4A717A52FC927@in.WebX.maYIadrTaRb...
> This is tedious - maybe a good extension idea would be a tool for updating
> the image files!
> "Juha Hänninen" wrote in message
> news:3CC0DB2A9AB48736CA63D3A979ECC551@in.WebX.maYIadrTaRb...
> > Patching AutoCAD 2000i Network Installation
> > Similar approach was also used to make AutoCAD 2002 SP1 installation
> package
> > Execute Service Pack 2 file (u090_u181p_swl.exe)
> > Locate file MSP2 file from the %TEMP% folder
> > Rename MSP2 file to MSP2.msp (Windows Installer Patch file)
> > Apply patch file to network installation point:
> > msiexec /p [path\name of update MSP file] /a [path\name of MSI file] /qb
> /L*
> > [path\name of log file]
> > Extract original ACAD1.cab file to empty directory
> > Replace original files with the SP2 ones (in folders 'Program Files' and
> > 'Windows' under installation point)
> > Unzip the old acad1.cab to a separate directory, copy multiple
ReadMe.txt
> > files to separate directories.
> > Create list of the files in the ACAD1.CAB
> > cabaarc.exe L ACAD1.CAB > list.txt
> > Append new files to the end of the list (e.g. list.txt) (List of the
> missing
> > files obtained with Wise Package Studio)
> > prodscan.exe
> > acadinfomsi.lsp
> > vercheck.arx
> > ProdIdUtil.txt
> > acsiobj.dbx
> > acinfomsi.lsp
> > Service_Pack_2_Readme.htm
> > Create a new ACAD1.CAB file:
> > cabarc N acad1.cab @list.txt
> > Replace the old ACAD1.CAB with the new one
> > You have now succesfully updated the AutoCAD 2000i installation point.
> > Use Group Policies to install AutoCAD 2000i to computers...
> > "SeanOD" wrote in message
> > news:f10d15d.-1@WebX.maYIadrTaRb...
> > Hi,
> > I've been searching through the documentation and browsed through the
post
> > but I can not find any info on how you go about applying a service pack
to
> a
> > A2k2 deployment image. No one has posted any questions about it here.
> > The documentation talks about how to apply it to a network-heavy type
> > network installation but I can't find a word about updating the
deployment
> > package.
> > Could someone either explain it to me or point me in the right
direction?
> > If it can't be done, how can I suppress the "reboot" window after the SP
> has
> > been installed? I have tried REBOOT=ReallySuppress and /Z but to no
avail.
> > Thanks in advance
> > John Doyle
