Installation & Licensing
Anyone know anything about the "Faro" installation during download?
4 REPLIES 4
488 Views, 4 Replies
Hi. I'm trying to install AutoCAD 2012, but it won't completely download. When I look at my log file, it says something about the Faro needing to be rebooted. I've restarted my computer multiple times, but it still says the same when I retry to install AutoCAD. Does anyone know where I can manually install Faro? I did this for .NET and Directx and the reboot went away. I'm hoping Faro is the problem. If anyone has any other suggestions, please help!
4 REPLIES 4
Patchy
Go to Control Panel and remove the Faro junk, then reinstall Autocad.
in reply to: Patchy
I uninstalled Faro and restarted my computer. I tried reinstalling AutoCAD, but it still failed. I've gotten rid of all the autodesk programs and tried installing AutoCAD 2012, but that still didn't work. I don't know what else to do.
Patchy
Go to Windows and search for FaroSDK.log (In Temp Folder) delete it.
Clean out everything in the Temp Folder
Try install Acad again.
in reply to: Patchy
Thank you so much! I deleted everything out of the Windows Temp folder as well as the Local Temp folder. I restarted my laptop and tried reinstalling AutoCAD 2012 and it worked!
Administrator Productivity
