And whatever backburner is, it doesn't like me. I don't know if it's related. I've also tried the repair option on the uninstall (which should be an option on the main autodesk menu). This was installed via USB.
This is for Ultimate 2013. 2012 works fine.
Solved by BillPIII. Go to Solution.
Anybody? I can't use any of the 2013 programs. They either return the SerialNum error or sit on 'splash' screen.
Since everyone else was busy, I fixed it myself.
Here is my hack solution. So if some things don't make sense or seem irrelevant, don't ask me why I did them. I flailed about until something worked.
This is for Windows 7 Btw.
1. Find a program called CCleaner and Run it.
2. Go to Control Panel -> Programs -> Turn Windows Features On/Off
3. Look for any .Net stuff and turn it off.
4. Go To Add/Remove program and try to delete the Windows.Net stuff. You need to delete one before the other. I don't remember which but it will complain if you guess wrong.
5. Go find a program called dotnetfx_cleanup tool. Download it. Extract it (don't run from inside the zip but copy those files into a directory) then run that.
5.b. doesn't hurt to run CCleaner again.
6. Go to C:\Windows\Microsoft.Net and look for the "Assembly" directory. Rename that something else.
7. Go download the "dotNetFX_Full_Setup" from Microsoft and run it.
Now 2013 works. But that was a PITA.
Here is some better and more specific info that covers a larger range of .NET problems:
After laughing an inappropriate amount of time at your humor, and feel the need to ask if you've found any other solution.
A workstation that functioned fine Friday is now unhappy, same .NET and SerialNUM Error, as you reported.
As much as I enjoy uninstalling all 20+ Microsoft Windows 7 Updates that installed this morning, I was hoping for something better.
The link would be good to post for others, but as of this morning, we are functional again.
Based on a suggestion from Subscription support, I tried the Repair Installation for Inventor in the Windows 7
"Control Panel\All Control Panel Items\Programs and Features"
It didn't work, so I went searching again.
Knowing it was a .NET issue I went and looked at the .NET 3.5.1 again. It can be toggled on and off under "Control Panel\All Control Panel Items\Programs and Features -- Turn Windows features on or off"
See solution 1 on this website.
The **** thing was turned OFF.
I KNOW it was turned on yesterday, because I toggled it several times.
I'm thinking the solution might be two steps.
1. Run the Inventor installation repair.
2. Turn the .NET 3.5.1. back ON.
Yes, I had already checked that plus did a number of various .net "fixes" without any luck. The repair install was my last ditch effort before re-formating and it worked. But no, try everything else first. Hopefully you got it just by doing what you did. But if all else fails:
http://windowssecrets.com/top-story/win7s-no-reformat-nondestructive-reinstall/
