• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    Alias cannot find DirectConnect
    171 Views, 2 Replies
    11-18-2012 09:32 AM
    Hi there!
    I am running Alias 2010 on 32-bit Windows XP and have not had any installation problems.  However, when I try to import an ipt I get "Translation of *.ipt failed due to DirectConnect not being installed.
    As I understand it DirectConnect should have been installed with Alias, but to be sure I downloaded and installed DirectConnect 2011.  Still no luck.
    Can anyone help?
    Please use plain text.
    Product Support
    Re: Alias cannot find DirectConnect
    11-19-2012 01:21 PM in reply to: Tomcam
    I would try to re-install Alias or repair it. Make sure that Direct Connect is included in the install.  Downloading and installing Direct Connect 2011 should not solve your problem.
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
    New Member
    11-20-2012 01:13 AM in reply to: david.lau
    Hi David
    Thanks for your speedy reply. I have reinstalled Alias including Direct connect.
    I am getting a runtime error   R6025 - pure virtual function call. Then the message Autodesk DirectConnect has encountered problem and needs to close.
    Any suggestions what I should do?
