Installation & Licensing
Akamai netsession interface failure
56 REPLIES 56
Message 1 of 57
bas146
39885 Views, 56 Replies
I have been trying repeatedly to install the student version of autocad 2013, and every time it starts the install stalls at "installing akamai netsession interface" and gives me a pop up box saying "network failure".
i have tried chrome, IE, and firefox.
56 REPLIES 56
Message 2 of 57
philip.s
in reply to: bas146
Hi Brent,
Can you try downloading via an alternative method such as Browser Download or Install Now?
Please let us know if you have additional issues or accept as a solution if this resolves the problem.
Message 3 of 57
bas146
in reply to: bas146
i just now realized that i am running vista. could that be the problem?
Message 4 of 57
philip.s
in reply to: bas146
Hi Brent,
That shouldn't affect the download as much as it would the actual install / usability. Per the sytem requirements, AutoCAD 2013 is not supported to run on vista. Is it necessary that run the current version, or would you be able to utilize a previous version (2012-2010 are also currently available in the Education Community)?
Message 5 of 57
bas146
in reply to: bas146
i was able to install it last night using the browser download. i think it stopped the first time i did the browser DL because i must have had a hickup in my internet connection.
i am able to open it up and start using it, exactly what does "not supported" mean? how much functionality will i be able to get out of it?
i am just learning autocad and we use 2013 in my class, is 2012 different enough that i will be confused from learning 2013 in school?
thank you for all the help.
Message 6 of 57
arlinpega.bibat
in reply to: bas146
Hi bas146:
When we say not supported, you can try and install the software, but it's either it won't or it may not run properly.This is why we have specific requirement, in case you enconter issues, our product experts would be able to assist you.
I hope this clarifies.
Have a nice day!
Best Regards,
Arlin Bibat
Message 7 of 57
jasen.coon
in reply to: bas146
I am having the exact same problem downloading autocad 2013 and I am using Windows 8.  The Akami netsession fails, everytime.  I have tried all methods of downloading and each has various problems and eventually fail.  The odd thing is I have previously used the install now option to download Inventor 2014 on the same computer.  Any idea what is going on??
Message 8 of 57
philip.s
in reply to: jasen.coon
Welcome to the community Jason!
Have you tried disabling your firewall, and/or turning off your antivirus software? What sort of errors are you getting with the Browser Download method?
Message 9 of 57
a01337525
in reply to: bas146
every time i try to download the autodesk inventor professional it tells me that the netsession client could not start
Message 10 of 57
philip.s
in reply to: a01337525
Welcome to the community Alejandro!
Are you able to try utilizing a different download method, specifically Browser Download?
From Matt: Download and Installation -> Software Download Links -> I need to redownload my product
Message 11 of 57
beejal100
in reply to: philip.s
i am having the same problem wtih windows 8 and i tried download now and install now, but i dont think it is because of my anti-virus software as i have Norton and it would notify me if some is dangerous and automatically close the program
Message 12 of 57
crosslpark
in reply to: bas146
I am having the same problem. I have windows 7 and on the "initializing" window, as soon as it says installing  Akamai netsession interface, it just stops with a little bit left to completion
Message 13 of 57
philip.s
in reply to: crosslpark
Welcome to the community Yash and Junho!
Did either of you try using the Browser Download option?
Message 14 of 57
alejandrogg10
Hi, I'm having the same problem, new netbook, and I'm having the network faliure in both ways, with the autodesk installer and with the direct download. Please if you can help or give me any way to solve the problem. I can't belive it's a problem of my netbook because I've bought it this morning but nothing is impossible...
I have also disabled the firewall and the antivirus.
Thankyou.
Message 15 of 57
philip.s
in reply to: alejandrogg10
Hello!
Were you able to try utilizing the afore mentioned Browser Download option?
Message 16 of 57
alejandrogg10
in reply to: beejal100
This "Download and Installation -> Software Download Links -> I need to redownload my product" finally work, and now I can work again, thank you so much!
Message 17 of 57
philip.s
Sure thing and for future viewers, our Virtual Agent has changed. Please check out the following for instructions on how to download current + supported previous versions.
How to re-download your software
Message 18 of 57
Momo251212
Thanks for the patience, support and reply. Smiley Happy
Message 19 of 57
gaetan.collaud
in reply to: bas146
I had this problem. After trying everything said on this thread. I just uninstall the Akamai Netsession Interface (you can find it in the control panel -> uninsatall program).
After a reboot, the installation of Inventor worked.
Cheers
Gaétan
Message 20 of 57
twisdom
It doesnt give that option. where do you find the browser download option?
Administrator Productivity
