Whenever I try to use the Akamai installer I get a message saying: Disk I/O Failure. Failed in writing contents file /Applications/Akamai/client.ini to disk. Help?
Have you tried using the alternate download method?
As a workaround Lets try to use our virtual agent as follows:
Select the 2nd Choice "Download Links "
Select your product
You are now presented with the choice to download your software.
asburyj, I am experiencing the exact same issues everyone else is on this thread. "I/O Disk failure, or Akamai netsession wont load" I am lost as to what is wrong. I attempted to select the link you offered but no luck. Any advice would be greatly appreciated. Thank you
Kyle
I am currently attempting to install Autodesk Inventor Professional 2017, however I have experienced this very same issue with AutoCAD as well and different years. and unfortunately the link doesnt seem to work, unless I dont understand it properly. It did open a new tab with a virtual agent window but the only options were "search" and Ask question" I believe. I am now attempting a Browser download to see if I can get any better results but so far its not working.
I just tested the Inventor Pro 2017 download links and they are working for me. I wonder is perhaps you have some browser security settings or something like that blocking the downloads? Regardless if you are getting the browser download working those are the same files you would get from the direct download links. Just make sure your browser download is kicking off all the files in the download I believe inventor pro 2017 has 3 files. If it's not download all 3 there may be a popup blocker or something stopping all the downloads from starting.
Alright, well I am currently using Mozilla Firefox so I will have to check my security settings. The browser download just finished downloading now Im going to attempt to install. I'll keep you posted.
Alright, So I attempted to select the file and a small screen appeared called "Autodesk Self Extract" and it asked me where to extract the file location, with which it was automatically filled with "C:\Autodesk\ ; so I clicked ok and an error message appears stating "Product download consists of multiple files, At least one file is missing or has not been downloaded yet." This is the second time I have attempted to Browser download. What are your thoughts?
Welcome to the Autodesk User's Community..
There's a couple of ways to properly download and install your Autodesk product to your machine. Please review this article and the solution it provides.
If the installation does fail using the preferred methods, please post your installation log file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you. Open your log file using Windows Notepad and perform a search on "/SN". Depending on the number of installation attempts, your serial # may be located throughout the log file. If present, remove or "X" out your serial # prior to posting.
Good luck on your installation and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hi! I solved this problem going to control panel > uninstall programs and search for FARO scanner production and uninstall it.
When I try to install Autocad again, it works.
