After installing Inventor, I discovered that I had 7 GB of stuff in Program Files\Common Files\Akamai\Cache.
Do I still need these files? Is this part of the AutoDesk Vault Client?
Solved by hashim.mundol. Go to Solution.
you can clear the cache folder, you will need to keep the installation source, which is usually in C:\Autodesk folder
