• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *montagne, michael
    Adlm battle
    94 Views, 3 Replies
    11-11-1999 03:06 PM
    My system admin. and I are having a discussion. Currently we run a
    standalone copy of AutoCad at each workstation. We do this primarily for
    speed. The drawing files all reside on network servers (NT4.0) and they are
    directly opened and worked on in those locations. I believe that we could
    save a lot of money by using the Adlm. That way we wouldn't have to buy a
    license for someone who only uses AutoCad a couple of times a month. She
    maintains that the network traffic would decrease overall network
    performance and cancel out any monetary gains. There are also the extra
    complications with installing a system different from the one we are
    familiar with. Does anyone have any input that may be germane to our
    discussion?
    -mjm
    Please use plain text.
    *Martin, Jason
    Re: Adlm battle
    11-11-1999 08:33 PM in reply to: *montagne, michael
    Yes using the adlm will increase network traffic, but so slightly that I
    doubt anyone would be able to tell. The adlm granting of licenses is
    extremely lightweight when you compare it to opening drawing files across
    the network. To use the adlm you will have to change the way that autocad
    is installed (at least as far as I know). You will have to create a network
    deployment to use the adlm. (It's really not that hard, see installation
    manual for information).
    The following is from a previous post by jerry milana (hope you don't mind
    jerry)
    "The license manager itself is passive. When AutoCAD is started it sends
    packets out to find a license manager. Once a connection is established a
    heart beat is established at the rate of one packet per minute from the
    AutoCAD workstation to the AdLM server and one per minute from the AdLM
    server to the workstation."
    One thing to note (at least this is what I remember) is to go ahead and
    specify the name of the adlm server for AutoCAD. Otherwise AutoCAD does a
    broadcast to search for a license when it starts.
    HTH
    jason martin
    frankfurt-short-bruza
    michael montagne wrote in message <80fhvj$lt924@adesknews2.autodesk.com>...
    are
    >discussion?
    >-mjm
    *Milana, Jerry
    Re:
    11-12-1999 09:31 AM in reply to: *montagne, michael
    Jason,
    By all means, feel free to quote my posts!
    To clarify the traffic issue, even the initial broadcast for a license manager
    is very light weight and it occurs only at program startup, once the connection
    is made between the AutoCAD session and the license manager, all packets are
    confined.
    For more information, you may want to take a look at
    http://www.autodesk.com/support/solutions/14592.htm, which explains the
    ACADSERVER variable. There is a lot more information available on AdLM at
    http://www.autodesk.com/support/autocad/2000ni.htm and
    http://www.autodesk.com/support/autocad/acad14ni.htm. The second URL is the R14
    network document page, AutoCAD 2000 and R14 network issues are essentially the
    same.
    Jerry Milana,
    Autodesk Product Support
    > jerry)
    > HTH
    > jason martin
    > are
    > >discussion?
    > >-mjm
    *Slusher, Mike
    Re: Adlm battle
    01-28-2000 08:11 PM in reply to: *montagne, michael
    When we upgraded from 12Dos to R14, our firm did go with networked licenses.
    We are small, only 15 licenses, but ADLM has saved us 2-4 seats easily.
    Initial ADLM Server setup has been a pain, but once it's running, it has
    been little problem. You mention NT server, so you should be configured for
    TCP/IP already. We have been using Novell and Win9x workstations - have
    just got a few NT workstations and are having some problems in the
    transition. ADLM traffic seems very lite - infact we run ADLM on an old
    unused 486. All in all, it's been good for us.
    Planning is really the key before implementing. There are some good tech
    help if you dig deep into the site. You do have to convert your older
    licenses and reinstall software at each workstation to use ADLM. If youre
    planning to upgrade to 2000 or purchasing new seats is the best time to
    start.
    Good luck!
